Galaxy
DX Radios DX95T2
Main
PCB (EPT690010C)
MECHANICAL / CHASSIS:
Ref#
Description |
MFR.
Part No.
MECHANICAL: DX-95T2 |
#T-149C-P14 |
Hardware
Ref#
Description |
MFR.
Part No.
FRONT PANEL DX-95T 100W |
PTDX55083A |
KNOB WASHER |
PT3600090A |
FRONT PANEL |
LED WINDOW |
PTDX55090A |
FRONT PANEL |
DISPLAY BAR DX-949 |
PTDX55040A |
DISPLAY WINDOW RED (54x18x1) |
PT2100031E |
DISPLAY WINDOW (CH) RED 30x18x1 |
PTDX55020B |
HIGH SWR ALERT |
KNOB (A-1) |
PT3600101A |
KNOB C-1 |
PT3600120A |
VOL/SQ |
OUTER KNOB |
PT3600170A |
MIC/TB |
OUTER KNOB |
PT3600170A |
ECHO/TIME |
OUTER KNOB |
PT3600170A |
FINE/COARSE |
OUTER KNOB |
PT3600170A |
VOL/SQ |
INNER KNOB |
PT3600180A |
MIC/TB |
INNER KNOB |
PT3600180A |
ECHO/TIME |
INNER KNOB |
PT3600180A |
FINE/COARSE |
INNER KNOB |
PT3600180A |
EL DIRVER PCB |
SHIELD HOUSING(EL) |
MT240N060X |
FRONT CHASSIS |
MTDX55060X |
ROTARY SW(1) |
SW CHASSIS |
MTDX55042X |
PUSH SW(1) |
PUSH BOTTON |
MTDX91040C |
HANDLER |
MT3600030S |
TOP HOUSING |
MT3600250X |
D SPRING A #6600 |
MT3600080T |
D SPRING B #7800 |
MT3600090T |
D SPRING D #8500 |
MT3600100T |
DC/S fixed plate |
MT3600180A |
ROTARY SW 24mm 5N |
EWRT32002S |
ROTARY SW 8N L=20MM |
EWRT32077S |
SW(02S/77S) |
SHIELD PLATE |
BTDX91030A |
ID PLATE DX-95T2 |
BTDX91021C |
EL PLATE DX-95T2 |
BTDX55141A |
PCB CONNECTOR/S 3P PH=2.54 (BLACK) |
EX07N49373 |
Bottom Housing(SP) |
SHIELD CLOTH 60x50x0.25t |
LZZZ60084Z |
CLAMP GT-100M |
GZZZ50000Z |
SLIDE SW |
MASK PLATE(SW) |
XZZZ90296A |
FOAM 15x30x11t |
XZZZ90021Z |
REAR HEATSINK(2) |
SOLDER PLATE |
XZZZ90002Z |
POWER PCB |
SPONGE 15x11x15mm |
XZZZ90406Z |
METER |
SPONGE 10x10x1tmm(d) |
XZZZ90418Z |
90002Z(2) |
SET SCREW M2x0.4Px4 |
JS052004MN |
Front panel (4) |
SET SCREW M3x0.5Px6 |
JS033006MN |
Chassis(12),42X(2) |
JS053006MN |
Main PCB(7) |
SET SCREW T3x6-2mm |
JS053006TN |
MAIN PCB(2) |
SET SCREW T3x4-2 |
JS053004TN |
SLIDE SW(10) |
SET SCREW M2.6x0.45Px4 |
JS052604MN |
SSSEB51H K905 271X KGS 1219x0.8 (SECC) 0.15 |
HZZZ76005Z |
Ref#
Description |
MFR.
Part No.
CHASSIS PARTS DX-95T2 |
#T-149C-P13 |
Ref#
Description |
MFR.
Part No.
SPEAKER 8ohm 2W 2in |
ES200820MC |
SIGNAL METER P-48U-9356 (100W) |
EX03N40503 |
MIC JACK |
MIC JACK 4P(MIC-C015) |
EX06N41242 |
J16-SP |
WIRE CONNECTOR/H 2P L=300MM PH=2.5 |
EX07N48120 |
40Z(J421)-METER |
WIRE CONNECTOR/H 2P L=100 PH=2 #28 |
EX07N48233 |
40Z(J412)-120Z(MOD LED PCB) |
WIRE CONNECTOR/H 2P L=210MM PH=2MM |
EX07N49448 |
J22-30Z(J309) |
WIRE CONNECTOR/H 2P-2P L=160mm PH=2 |
EX07N48921 |
41A(J403)-40Z(J402) |
WIRE CONNECTOR/H 2P-2P L=145MM PH=2 |
EX07N48850 |
Q41-40Z(J420) |
WIRE CONNECTOR/H 2P-2P L=400mm� PCS |
EX07N49030 |
J17-40Z(J423) |
EX07N49031 |
J25-30Z(J305) |
WIRE CONNECTOR/H 2P-2P L=400 PH=2 |
EX07N49363 |
J10-40Z(J408) |
WIRE CONNECTOR/H 2P-2P L=200 PH=2MM |
EX07N49100 |
J26-40Z(J409),J7-40Z(J426) |
WIRE CONNECTOR/H 2P-2P L=250mm PH=2 |
EX07N48917 |
30Z(J308)-41A(J401) |
WIRE CONNECTOR/H 3P-3P L=200 PH=2 |
EX07N49212 |
J11-41A(J404) |
WIRE CONNECTOR/H 3P-3P L=100mm PH=2 |
EX07N48914 |
J18-SW |
WIRE CONNECTOR/H 3P L=400mm PH=2mm |
EX07N48988 |
J6-40Z(J411) |
WIRE CONNECTOR/H 3P-3P L=180 PH=2 |
EX07N49209 |
J21-30Z(J306) |
WIRE CONNECTOR/H 4P-4P L=160 PH=2MM |
EX07N49101 |
J20-41A(J402) |
WIRE CONNECTOR/H 5P-5P L=120 PH=2 |
EX07N49213 |
J5-40Z(J403) |
EX07N49210 |
J13-40Z(J404,410) |
WIRE CONNECTOR/H 6P-3P-2P L=120PH=2 |
EX07N49479 |
J9-40Z(J415,416) |
WIRE CONNECTOR/H 6P-3P-3P L=120PH=2 |
EX07N49216 |
J3-40Z(J422) |
WIRE CONNECTOR/H 5P-5P L=400 PH=2 |
EX07N49208 |
J14-SW |
WIRE CONNECTOR/H 7P L=100MM PH=2MM |
EX07N49087 |
J1-40Z(J414)-SW |
WIRE CONNECTOR/H 9P-2P L=150 |
EX07N49211 |
30Z(J301)-MAIN PCB |
WIRE CONNECTOR/H 10P L=120mm PH=2mm |
EX07N48910 |
POWER PCB |
WIRE CONNECTOR/H #18 6P L=230/210mm |
EX07N49288 |
POWER PCB(J5)-MAIN PCB(B+/B-) |
WIRE CONNECTOR/H 2P PH=2.5 250(#22) |
EX07N49262 |
POWER |
BEAD COIL |
ECBAD18573 |
11D(J2)-MAIN PCB |
WIRE CONNECTOR/H 4P L=280mm PH=2mm |
EX07N49305 |
11D(J1)-MAIN PCB |
WIRE CONNECTOR/H 2P L=350MM PH=2.5 |
EX07N48212 |
POWER
PCB(I/P)-MAIN PCB, |
CABLE RG-316U 250mm SINGLE SIDE |
WX0412925A |
Ref#
Description |
MFR.
Part No.
SET CHASSIS ASS'Y DX-93T(100W) |
#T-149A-1-P15 |
Hardware
Ref#
Description |
MFR.
Part No.
DC FAN 12V DF1204SH |
EX13N46014 |
ANT JACK |
EX06T41019 |
REAR HEATSINK |
MTDX91012A |
LEFT SIDE CHASSIS |
MTDX91020X |
RIGHT SIDE CHASSIS |
MTDX91030X |
HEATSINK (PA) |
MT2970062A |
HEATSINK COVER/TOP Galaxy |
MT2970081B |
SHIELD COVER(PA) |
MT2970091X |
61A |
FAN CLIP |
MT2970110X |
SP |
BOTTOM HOUSING |
MT3600270X |
10A |
SHIELD CLOTH 100x25x0.3t |
LZZZ60085Z |
SHIELD COVER(PA)(x6) |
JS053006MN |
HEARTSINK(4) |
SET SCREW M5x0.75Px8 |
JS055008MB |
ANT JACK(1) |
SOLDER PLATE L=35mm |
XZZZ90423Z |
Ref#
Description |
MFR.
Part No.
PACKING: DX-95T2 |
#T-149C-P18 |
MIC (#R-201) SRA-201 (4PIN) |
EX04N40719 |
POWER CORD(#12) 3000MM 30A |
WA9212300Q |
I/M DX-95T2 |
AT0949010R |
Galaxy |
MIC NAME PLATE GALAXY |
BT2100020A |
SER NO LABEL |
LZZZ61307Z |
SERIAL NO.LABEL |
LMZZL0009B |
CHECK PASS LABEL |
LMZZL0013A |
Carton |
PVC BAG 600x410x830x0.07t |
UB07604183 |
Set |
PVC BAG 290x450x0.05tmm |
UB052945ZZ |
DC Cord |
PVC BAG 70x250x0.05tmm |
UB050725ZZ |
Spare Parts |
PVC BAG 100x150x0.05tmm |
UB051015ZZ |
POLYON BOTTOM |
UPT360001C |
CARD BOARD 336mmx215mmx5�h |
UDT480001D |
CARD BOARD |
UDT480001A |
CARTON DX-95T2 |
UCT480010D |
GIFT BOX DX-95T2 |
UGT480001D |
SET SCREW T3.5x8-2 |
JS013508TH |
SET SCREW W5x10-1 |
JS015010WH |
OUT-TOOTH WASHER 5.5x10x0.3tmm |
JW315510CN |
IN-TOOTH WASHER 4x8x0.3tmm |
JW324008CN |
MOUNTING SCREW BLACK |
XZZZ90007Z |
MIC STOPPER |
XZZZ90008Z |
FIBER WASHER |
XZZZ90188Z |
HANDLER(x2) |
RUBBER PAD |
XZZZ90433A |
Copyright � 2003 CBTricks.com
Disclaimer: Although the greatest care has been taken while compiling
these documents,
