Galaxy
DX Radios DX95T2
PLL
Alignment
See Alignment
Locations
SETTINGS | CONNECTION |
ADJUST
ADJUST FOR |
10.240 MHz PLL REFERENCE:
RX Mode, AM, Band E, Ch. 1 |
Connect Frequency counter to IC3 Pin 4. |
Check for 10.2400MHz ±200 Hz. If tolerance is beyond this, replace X1 (10.240MHz). |
VCO VOLTAGE:
RX Mode, AM, Band E, CH. 1 |
Connect DC voltmeter to TP2 |
L14
Adjust for 2.75 VDC
±0.1 Check Band A, CH. 1 for approx. 2.0V. and Band H. CH. 40 for approx. 6.0V. |
VCO OUTPUT: RX Mode, AM, Band E, CH. 1 |
Connect scope to TP3 |
L15
Adjust for max. RF |
PLL MIXER OSCILLATOR:
RX Mode, AM, Band E, CH. 1 Set Fine and coarse clarifier control to 12 oclock position. Set clarifier switch to RX/TX |
Connect Frequency Counter to TP3. |
L20
AM: Adjust for
16.2700MHz ±20 Hz. |
L21
USB: Adjust for
16.2725MHz ±20 Hz. |
L22
LSB: Adjust for
16.2675MHz ±20 Hz. |
TX OFFSET FREQUENCY:
Set mode to LSB RX |
VR7
Key TX; Adjust for
FREQUENCY COUNTER:
Set mode to AM RX Band E, CH.1 |
VC1 on Ch Sel / Counter PCB (EPT091V31Z)
Adjust VC1 on counter PCB for correct reading on frequency display.
FIXED CLARIFIER:
AM RX Mode Band E, CH. 1 Set clarifier switch to OFF |
VR907
on VR PCB (EPT091V91Z) |
AM: Adjust for correct
reading on frequency display |
