Galaxy DX Radios DX95T2
Transmitter Alignment
See Alignment Locations
SETTINGS CONNECTION
ADJUST
ADJUST FOR
Remove TP7-TP9 Jumper PCB.
TX CARRIER OSCILLATORS:
AM TX Mode
Band E CH. 1
Connect Frequency Counter to TP6
L25
LSB/TX mode: Adjust for 10.6975MHz �20Hz.
L24
USB/TX mode: Adjust for 10.6925MHz �20 Hz.
Connect Frequency Counter to TP5
L23
AM/TX mode: Adjust for 10.6950MHz �20 Hz.
DRIVER BIAS: (2SC2166)
Set Radio to:
Band E, Ch.1
Mode to USB
MIKE GAIN at minimum.
Connect DC Ammeter between TP7 and TP9.
VR12
Key TX adjust for 75mA.
FINAL BIAS: (2SC2312)
Set Radio to:
Band E, Ch.1
Mode to USB
Connect DC Ammeter between TP7 and TP8.
VR10
Key TX & adjust for 50mA.
Replace TP7-TP9 Jumper PCB.
RF AMP CHAIN:
Set mode to AM.
Set RF power control fully clockwise.
Connect wattmeter to ANT output.
L44, L43,
L42, L40,
L44
Key TX & adjust (in order) for maximum RF output . Recheck power across entire freq range.
Re-adjust L44 for minimum SSB distortion.
SSB CARRIER BALANCE:
Set mode to USB
MIKE GAIN to minimum.
VR6
Key TX, adjust for min. carrier leakthrough on scope or wattmeter. Recheck on LSB mode. If necessary readjust for best balance of sideband suppression between LSB & USB
SSB APC:
Set mode to USB
Set RF power fully clockwise.
Connect DC voltmeter from pcb ground to TP7
VR17
In TX, adjust for 8.5vdc
SSB ALC:
Mode to USB.
MIKE GAIN to maximum.
Inject two-tone audio signal of 700Hz and 1900Hz, 30 mV to Mic input.
VR13
L44
In TX, adjust for
100 watts PEP.
Adjust for minimum distortion on scope
AM CARRIER POWER:
Set mode to AM,
RF Power SW to HI.
CAUTION! Do not exceed power levels. Damage to power transistors and inability to achieve 100% modulation from insufficient audio power will result.
 VR14
Set RF PWR fully clockwise
adjust VR14 for 40 watts
VR18
Set RF PWR fully counter clockwise.
Adjust for 10 watts
RF METER:
Set mode to AM,
RF Power fully clockwise
Meter Switch to PWR
VR9
Adjust so meter agrees with Wattmeter.
AMC:
Mode to AM.
Inject audio signal of 1KHz at 30mV to Mic input.
Connect modulation meter to ANT output.
VR16
Adjust for 100% modulation depth.
MODULATION METER:
Mode to AM.
Meter Switch to MOD
VR15
Adjust so meter agrees with modulation meter.
Mod Lamp Adjust:
Mode to AM.
Front Panel Switch to Mod Lamp
VR910
Adjust so that lamp illuminates at approx. 75% modulation
FM DEVIATION:
Mode to FM
Inject 1 KHz, 30 mV audio signal at mike jack.
Connect deviation meter to ANT output.
VR5
Adjust for total deviation of 4.5 KHz.
Copyright © 2004 CBTricks.com
