Galaxy DX Radios DX95T2
VR PCB (EPT095T40Z)
Trace Layout
Parts List
Ref#
Description
MFR. Part No.
VR PCB (DX-95T2) EPT095T40Z
#T-149C-P09
VR PCB 151.5x80x1.6tmm(d)
EPT095T40Z
Resistors
Ref#
Description
MFR. Part No.
R403
CHIP/F/R (SMD) 47 OHM 0.1W
RCY014704Z
R404
CHIP/F/R (SMD) 6.8K OHM 0.1W
RCY016824Z
R405
CHIP/F/R (SMD) 0 OHM 0.1W
RCY010004Z
R406
RCY010004Z
Capacitors
Ref#
Description
MFR. Part No.
C401
CHIP/C 0.001UF 50WV
CK1102AB7L
C402
CHIP/C 0.01UF 50WV K X7R
CK1103AB5X
C403
CHIP/C 0.001UF 50WV
CK1102AB7L
C404
CHIP/F/R (SMD) 10K OHM 0.1W
RCY011034Z
C405
CK1103AB5X
Diodes
Ref#
Description
MFR. Part No.
D401
DIODE (S.M.D.) 1N4148
ED1N04148Y
Potentiometers
Ref#
Description
MFR. Part No.
VR401 (VOL/SQ)
V/R(RK097221101K) 50KB/50KA W/SW
RV50303522
VR402 (MIC/RF GAIN)
V/R 1KA/1KB W/PUSH SW
RV10203603
VR403 (DIM/PWR)
V/R 5KB/5KB W/PUSH SW
RV50203571
VR404 (FINE/COAR)
V/R 20KB/1KB W/PUSH SW
RV20303568
VR407
S/F/R (SMD) 10K (TMC3KJ)
RE103Y0131
VR410
S/F/R (SMD) 1K (TMC3KJ)
RE102Y0128
Transistors
Ref#
Description
MFR. Part No.
Q401
T/R (SMD) DTA143EK
TYDTA143EK
Q402
T/R (SMD) DTA124EUAT106
TYDTA124EA
Inductors
Ref#
Description
MFR. Part No.
L401
CHOKE COIL (SMD) 5.6UH TC J
YCTLI5653C
L402
BEAD FERRITE COIL WB-403025
YCBAD18581
Connectors
Ref#
Description
MFR. Part No.
J401
JUMPER WIRE 7x19MMx7
WX01070719
J402
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
J403
PCB CONNECTOR/S 5P PH=2MM (WHITE)
EX07W48826
J404
PCB CONNECTOR/S 3P PH=2MM (WHITE)
EX07W48824
J407
PCB CONNECTOR/S 3P T PH=2.5
EX07N41216
J408
EX07N48223
J409
EX07N48223
J410
EX07N48223
J411
EX07N48350
J412
EX07N48223
J413
EX07N48223
J414
EX07N48223
J415
EX07N48350
J416
EX07W48824
J420
EX07N48223
J421
EX07N48223
J422
EX07N48222
J423
EX07N48223
J426
EX07N48223
Copyright © 2003 CBTricks.com
