Galaxy
DX Radios DX979
SPEAKER 8ohm 3W 3.5in |
ES300835SQ |
DC CORD W/FUSE SOCKET |
WA0012185A |
SIGNAL METER P-48U-9109 |
EX03N40482 |
MICROPHONE ASSY,4P BLACK DMC507-012 |
EX04N40002 |
MIC JACK 4P |
EX06N41101 |
FUSE 125V 4A |
EX02N40206 |
ID PLATE DX-979 |
BT0919010B |
EL PLATE |
BT0919020A |
FCC PLATE DX-979 |
BT0919040C |
MIC NAME PLATE GALAXY |
BT2100020A |
EL PCB |
PCB CONNECTOR/S 3P PH=2.54 (BLACK) |
EX07N49373 |
FRONT PANEL |
PT0919010A |
FRONT HOUSING |
PT0919020A |
CH KNOB TR-396 |
PT148N021A |
VR KNOB TR-396 |
PT148N031A |
OUTER KNOB |
PT148N090A |
INNER KNOB |
PT148N100A |
DISPLAY WINDOW (CH) RED |
PTDX55020B |
DISPLAY BAR DX-949 |
PTDX55040A |
FRONT CHASSIS |
MT0919010X |
TOP HOUSING |
MT1200011K |
BOTTOM HOUSING |
MT1200210K |
D SPRING A #6600 |
MT3600080T |
D SPRING B #7800 |
MT3600090T |
D SPRING D #8500 |
MT3600100T |
MOUNTING BRACKET |
MT1200090A |
SW CHASSIS |
MTDX55042X |
SPK |
RUBBER COVER |
QT7799010A |
KNOB WASHER |
PT3600090A |
FOAM 15x30x11t |
XZZZ90021Z |
MASK PLATE(SW) |
XZZZ90296A |
MOUNTING SCREW BLACK |
XZZZ90007Z |
MIC STOPPER |
XZZZ90008Z |
FIBER WASHER |
XZZZ90188Z |
INSULATING PLATE 12x16x1t |
XZZZ90064Z |
SHIELD CLOTH 10x170x0.3t |
LZZZ60082Z |
CODE RULE |
LZZZ62079Z |
CHECK PASS LABEL |
LMZZL0013A |
PART 15 LABEL (FCC) |
LZZZ61570A |
SERIAL NO.LABEL |
LMZZL0009B |
BLIND RIVET 3.2x6mm (AL) |
JF413206ZX |
Front Panel |
SET SCREW M3x0.5Px6 |
JS033006MN |
CH(2) |
JS053006MN |
T/H(4) |
JS053006MN |
B/H(4) |
JS053006MN |
PCB(5) |
SET SCREW T3x6-2mm |
JS053006TN |
METER(4) |
JS053006TN |
PLATE |
SET SCREW M3x0.5Px4 |
JS053004MN |
SPK(4) |
SET SCREW M3x0.5Px8 |
JS053008MN |
Slide SW(6) |
SET SCREW M2.6x0.45Px4 |
JS052604MN |
SPK(4) |
NUT WITH WASHER M3x3.5t |
JN263035ZS |
SET SCREW W5x10-1 |
JS015010WH |
SET SCREW T3.5x8-2 |
JS013508TH |
OUT-TOOTH WASHER 5.5x10x0.3tmm |
JW315510CN |
IN-TOOTH WASHER 4x8x0.3tmm |
JW324008CN |
I/M DX-979 |
AT0919030A |
CHIP/C(SMD) 82PF 50WV J CH C306 (L43 PIN4.6 COPPER SIDE) |
CK1820AA4A |
DC(2) |
C/C 0.01UF 50WV SL Z |
CC0501037L |
ANT JACK |
EX06T41019 |
DC JACK 3P |
EX06T40007 |
DIODE LT6A400 |
EDLT6A400Z |
SET CHASSIS |
MT0919030X |
DC SOCKET HOLDER |
MT3600050X |
MIC JACK(x1) |
SOLDER PLATE |
XZZZ90098Z |
DC(2) |
JS053008MN |
