Galaxy
DX Radios DX979
Frequency Modification
NOTE: If you have even the slightest doubts or the proper equipment , it would be wise to have someone else you trust perform the mod for you. SO TAKE YOUR TIME AND DOUBLE CHECK YOUR WORK!!!! |
The
Ranger 8719 does not use internal pull-up resistors which means you will
need to cut the traces of pin 10 and pin 11 then bridge the cut trace with
4.7k ohm resistors.
With
pin 11 low - 26.815 to 26.955 on CH. 15 to 27 NOTE: |
