Galaxy DX Radios DX979
PLL Alignment
See Alignment Locations
SETTINGS CONNECTION
ADJUST
ADJUST FOR
VCO:
Disconnect the "short PCB" from TP7, TP8 and TP9.
Set radio to CH 20 AM RX mode. Clarifier setting in 12 o'clock.
Connect FC to IC3 Pin 8
Connect DVM to TP2.
Connect Oscope to TP3
VC1
L14
L15
Adjust for 10.24000MHz ±20Hz.
Adjust for 3.0 VDC ±0.1
Adjust for max.
AM Frequency:
Connect frequency counter to TP3.
L20
16.51000 MHz ±20Hz.
USB Freq:
Set radio to CH 20 USB mode.
L21
16.51250 MHz ±20Hz.
LSB Freq:
Set radio to CH 20 LSB mode.
L22
16.50750 MHz ±20Hz.
Copyright © 2003 CBTricks.com
