Galaxy DX Radios DX979
Receiver Alignment
See Alignment Locations
SETTINGS CONNECTION
ADJUST
ADJUST FOR
AM Sensitivity:
Set radio to CH 19 AM RX MODE.
Set NB/ANL switch to OFF position.
Clarifier setting at 12 o'clock.
RF Gain fully clockwise.
SQ fully counter clockwise.
VOL control at 2 o'clock.
Connect AF VTVM or scope across speaker terminals.
Connect RF SG to antenna jack Output Frequency 27.185 MHz, MOD 30%.
(in order)
L2, L3, L5, L6, L7, L8, L9, L10
Audio output > 2V@10dB S/N > 10 dB.
Set radio to CH 40 AM RX mode.
Set radio to CH 1 AM RX mode.
RF SG setting 27.405 MHz. 100uV. Mod 30%
RF SG setting 26.965 MHz, 100uV. Mod 30%.
L5,L6
For Balance Between CH 1 and CH 40.
USB Sensitivity:
Set radio to CH 19 USB mode.
VOL control fully clockwise.
RF SG setting to 27.186 MHz @ 0.5 uV
MOD to off
L11, L12
Audio output
> 2V S/N 10 dB
LSB Sensitivity:
Set radio to CH 19 LSB mode.
RF SG setting to 27.184 MHz @ 0.5 uV
MOD to off
RF Generator to ANT Jack
L11, L12
Audio output
> 2V S/N 10 dB
NB Adjust:
Set radio to CH 18 AM RX mode
RF SG setting 27.185 MHz @ 1000uV
MOD Off.
Set NB/OFF switch to ON position.
Connect Multi-meter to TP1 (D2 cathode).
L1
DC voltage to max.(>2.0V)
AM Squelch:
Set radio to CH 19 AM mode
SQ control fully clockwise.
RF SG setting 27.185 MHz, 20mV. Mod 30%.
VR4
Adjust very slowly until squelch just closes
SSB Squelch:
RF SG setting 27.186 MHz, 20 mV. Mod off.
VR3
AM S-Meter:
Set radio to CH 19 AM mode.
Meter switch at S/RF position.
RF SG setting to 27.185 MHz @ 100 uV MOD 30%,
VR1
Adjust needle on S-Meter to "9" on the S scale
SSB S-Meter:
S/RF switch at S/RF position.
RF SG setting 27.185 MHz, 100uV. Mod Off.
VR2
Copyright © 2003 CBTricks.com
