Galaxy
DX Radios DX98VHP
Channel Selector / Frequency
Counter PCB (EPT99HP20A)
Part Layout Top View
Trace Layout Top View
Trace Layout Bottom View
Parts List
Ref#
Description |
MFR.
Part No.
ROTARY SW/DX-98HP EPT99HP20A� |
#T-149D-P03 |
EPT99HP20A |
EPT99HP20A |
Resistors
Ref#
Description |
MFR.
Part No.
R5 |
CHIP/F/R (SMD) 10K OHM 0.1W |
RCY011034Z |
R6 |
CHIP/F/R (SMD) 470 OHM 0.1W |
RCY014714Z |
R7 |
CHIP/F/R (SMD) 100 OHM 0.1W |
RCY011014Z |
R9 |
CHIP/F/R (SMD) 330 OHM 0.1W |
RCY013314Z |
R10 |
RCY011014Z |
R11 |
RCY011014Z |
R12 |
RCY011014Z |
R13 |
RCY011014Z |
R14 |
RCY011014Z |
R15 |
RCY011014Z |
R16 |
RCY011014Z |
R17 |
RCY011014Z |
R18 |
RCY011014Z |
R19 |
RCY011014Z |
R20 |
RCY011014Z |
R21 |
RCY011014Z |
R22 |
RCY011014Z |
R23 |
RCY011014Z |
R24 |
RCY011014Z |
R25 |
RCY011014Z |
R26 |
RCY011014Z |
R27 |
RCY011014Z |
R28 |
RCY011014Z |
R29 |
RCY011014Z |
R30 |
RCY011014Z |
R31 |
RCY011014Z |
R32 |
CHIP/F/R (SMD) 1K OHM 0.1W |
RCY011024Z |
R33 |
RCY011034Z |
R34 |
CHIP/F/R (SMD) 100K OHM 0.1W |
RCY011044Z |
R35 |
RCY011034Z |
R36 |
RCY013314Z |
R37 |
CHIP/F/R (SMD) 39K OHM 0.1W |
RCY013934Z |
R38 |
RCY011034Z |
R39 |
RCY011034Z |
R40 |
RCY011034Z |
R43 |
CHIP/F/R (SMD) 820 OHM 0.1W |
RCY018214Z |
R44 |
CHIP/F/R (SMD) 47K OHM 0.1W |
RCY014734Z |
R45 |
CHIP/F/R (SMD) 27K OHM 0.1W 5% |
RCY012734Z |
R46 |
CHIP/F/R (SMD) 15K OHM 0.1W 5% |
RCY011534Z |
R47 |
CHIP/F/R (SMD) 6.8K OHM 0.1W |
RCY016824Z |
R50 |
CHIP/F/R (SMD) 4.7K OHM 0.1W |
RCY014724Z |
R51 |
RCY014724Z |
R52 |
RCY013314Z |
R53 |
CHIP/F/R (SMD) 47 OHM 0.1W |
RCY014704Z |
R54 |
CHIP/F/R (SMD) 220 OHM 0.1W |
RCY012214Z |
R55 |
CHIP/F/R (SMD) 1M OHM 0.1W |
RCY011054Z |
R56 |
RCY011024Z |
R57 |
RCY011034Z |
R58 |
RCY011034Z |
R59 |
RCY011034Z |
R58 |
RCY011024Z |
R62 |
CHIP/F/R (SMD) 0 OHM 0.1W |
RCY010004Z |
R313 |
RCY011024Z |
R314 |
RCY011024Z |
R320 |
RCY011024Z |
R423 |
RCY018214Z |
R12 |
RCY011024Z |
R13 |
RCY011024Z |
R14 |
RCY011024Z |
Capacitors
Ref#
Description |
MFR.
Part No.
C1-1 |
E/C 100UF 16WV Z |
CE0161077Z |
C1 |
E/C 100UF 16WV Z |
CE0161077Z |
C2 |
CHIP/C 0.01UF 50WV K X7R |
CK1103AB5X |
C3 |
CK1103AB5X |
C4 |
CHIP/C 0.1UF 25WV Z Y5V |
CK2104AB7R |
C5 |
CK1103AB5X |
C6 |
CK2104AB7R |
C7 |
CK2104AB7R |
C8 |
CK2104AB7R |
C9 |
CK2104AB7R |
C11 |
CHIP/C 4.7UF 16WV Z Y5V |
CK5475AA7R |
C12 |
CK2104AB7R |
C13 |
CK1103AB5X |
C14 |
CK1103AB5X |
C15 |
CK2104AB7R |
C16 |
CK2104AB7R |
C17 |
CK2104AB7R |
C18 |
E/C 100UF 16WV Z |
CE0161077Z |
C19 |
E/C 100UF 16WV Z |
CE0161077Z |
C20 |
E/C 100UF 16WV Z |
CE0161077Z |
C21 |
CK1103AB5X |
C23 |
CHIP/C 10PF 50WV D CH |
CK1100AB2A |
C24 |
CHIP/C 1UF 16WV Z Y5V |
CK5105AB7R |
C25 |
CK2104AB7R |
C26 |
CK1103AB5X |
C27 |
CK1103AB5X |
C28 |
CK2104AB7R |
C29 |
CK2104AB7R |
C30 |
CK1103AB5X |
Ref#
Description |
MFR.
Part No.
VC1 |
TRIMMER/C (SMD) K20PF 3.8p |
CV038200AY |
Integrated Circuits
Ref#
Description |
MFR.
Part No.
IC1 |
I.C. (SMD) (RANGER) 48PINKHT48R50A-48 |
YNRGFC04SP |
IC2 |
I.C. (SMD) (PHILIPS) K74HC161D 16PIN |
YNPHHC161D |
IC3 |
I.C. (SMD) (JRC) KNJM78L05UA-TE1 3PIN |
YNJR78L05Z |
Transistors
Ref#
Description |
MFR.
Part No.
Q4 |
T/R (SMD) 2SC2712GR-TE85L |
TY2SC2712G |
Q5 |
TY2SC2712G |
Q7 |
TY2SC2712G |
Q8 |
TY2SC2712G |
Q9 |
T/R (SMD) 2SC2714Y-TE85L |
TY2SC2714Z |
Q10 |
T/R (SMD) 2SA1162GR-TE85L |
TY2SA1162G |
Diodes
Ref#
Description |
MFR.
Part No.
D12 |
DIODE (SMD) K1SS355 |
EDSS00355Y |
D13 |
EDSS00355Y |
D18 |
EDSS00355Y |
D19 |
EDSS00355Y |
D20 |
EDSS00355Y |
D21 |
EDSS00355Y |
D22 |
EDSS00355Y |
D23 |
EDSS00355Y |
D24 |
EDSS00355Y |
D29 |
EDSS00355Y |
D30 |
EDSS00355Y |
D31 |
DIODE (SMD) K1N4148 |
ED1N04148Y |
D32 |
ED1N04148Y |
D321 |
EDSS00355Y |
Inductors
Ref#
Description |
MFR.
Part No.
L1 |
CHOKE COIL (SMD) G100UH TF J |
YCTLI1073F |
Switches
Ref#
Description |
MFR.
Part No.
ROTARY SW |
KGPS-0501 |
EWRT32000S |
SW CHASSIS |
MTDX55042X |
Crystals
Ref#
Description |
MFR.
Part No.
X201 |
CRYSTAL HC-49/U K4.500MHz |
EYCAP04500 |
Connectors
Ref#
Description |
MFR.
Part No.
J201 |
PCB CONNECTOR/S 10P PH=2 |
EX07N48209 |
J202 |
PCB CONNECTOR/S 3P PH=2MM |
EX07N48350 |
J203 |
PCB CONNECTOR/S 4P PH=2MM |
EX07N48490 |
J204 |
PCB CONNECTOR/S 2P PH=2MM |
EX07N48223 |
