Galaxy DX Radios DX98VHP
ECHO PCB (EPT99HP50A)
Trace Layout
Schematic Diagram
Ref#
Description
MFR. Part No.
EVRP ECHO (DX-98HP) EPT99HP50A
#T-149D-P06
EPT99HP50A
Resistors
Ref#
Description
MFR. Part No.
R1
CHIP/F/R (SMD) 2.2K OHM
RCY062224Z
R2
CHIP/F/R (SMD) 1K OHM
RCY061024Z
R3
CHIP/F/R (SMD) 5.6K OHM
RCY065624Z
R4
CHIP/F/R (SMD) 6.8KOHM 0.1W
RCY066824Z
R5
CHIP/F/R (SMD) 1MEG OHM
RCY061054Z
R6
RCY061024Z
R7
CHIP/F/R (SMD) 100K OHM
RCY061044Z
R8
CHIP/F/R (SMD) 15K OHM
RCY061534Z
R9
RCY061534Z
R10
CHIP/F/R (SMD) 3.3K OHM
RCY063324Z
R11
CHIP/F/R (SMD) 10 OHM
RCY061004Z
R12
RCY062224Z
R13
CHIP/F/R (SMD) 33K OHM
RCY063334Z
R14
CHIP/F/R (SMD) 22K OHM
RCY062234Z
R15
CHIP/F/R (SMD) 10K OHM
RCY061034Z
R16
RCY062234Z
R17
RCY061004Z
R18
RCY062234Z
R19
RCY061024Z
R20
CHIP/F/R (SMD) 47K OHM
RCY064734Z
R21
RCY061034Z
R22
RCY062234Z
R23
CHIP/F/R (SMD) 100 OHM
RCY061014Z
R24
RCY061054Z
R25
CHIP/F/R (SMD) 39K OHM
RCY063934Z
R26
RCY063334Z
R28
RCY064734Z
R29
RCY063324Z
R30
CHIP/F/R (SMD) 27K OHM
RCY062734Z
R31
RCY064734Z
R32
RCY061034Z
R33
RCY062734Z
R38
RCY062224Z
R39
CHIP/F/R (SMD) 4.7K OHM
RCY064724Z
R40
RCY061034Z
R41
RCY064724Z
R42
CHIP/F/R (SMD) 220K OHM
RCY062244Z
R43
RCY061024Z
Capacitors
Ref#
Description
MFR. Part No.
C1
CHIP/C 1UF 16WV Z Y5V
CK5105AD7R
C2
CHIP/C 0.1UF 25WV Z Y5V
CK2104AD7R
C3
CHIP/C 0.0022UF 50WV K X7R
CK1222AD5X
C5
CHIP/C 0.01UF 50WV K X7R
CK1103AD5X
C6
CK1103AD5X
C7
T/C (SMD) ("B"CASE) 47UF 6.3WV
CTY064767B
C8
CHIP/C 33PF 50WV J CH
CK1330AD4A
C9
CK2104AD7R
C10
CK1103AD5X
C11
CHIP/C 4.7UF 16WV Z Y5V
CK5475AA7R
C12
CK2104AD7R
C13
CK1103AD5X
C14
CHIP/C 560PF 50WV K CH
CK1561AD5A
C15
CK5105AD7R
C16
CK2104AD7R
C17
CK5105AD7R
C18
CHIP/C 330PF 50WV K CH
CK1331AD5A
C19
CTY064767B
C20
CK2104AD7R
C21
CK2104AD7R
C22
CK2104AD7R
C23
CK2104AD7R
C24
CK2104AD7R
C25
CK1561AD5A
C26
CHIP/C 0.047UF 50WV K X7R
CK1473AD5X
C27
CHIP/C 0.001UF 50WV K X7R
CK1102AD5X
C28
CK1102AD5X
C30
CK1103AD5X
C31
CK5105AD7R
C32
CK5105AD7R
C33
CK1473AD5X
C34
CHIP/C 0.022UF 50WV K X7R
CK1223AD5X
C35
CK1103AD5X
C36
CK1103AD5X
C37
CK2104AD7R
C39
CK1103AD5X
C40
CK2104AD7R
C41
CK5475AA7R
C42
CK2104AD7R
C43
CK2104AD7R
C44
CK2104AD7R
C45
CK2104AD7R
C46
CK2104AD7R
C47
CK2104AD7R
C48
CK2104AD7R
VC1
TRIMMER/C (SMD) 20PF 3.8p
CV038200AY
Integrated Circuits
Ref#
Description
MFR. Part No.
IC1
I.C. (JRC) (SMD) NJM4558M 8PIN
YNJR04558M
IC2
I.C (SMD) ES56033S 16PIN
YNES56033S
IC3
I.C. (WINLEAD) (SMD) WIN8072 16PIN
YNWN08072Z
Transistors
Ref#
Description
MFR. Part No.
Q1
T/R (SMD) 2SC2712GR-TE85L
TY2SC2712G
Q2
F.E.T. (SMD) 2SK208
FY2SK0208Z
Q3
T/R (SMD) RN1403-TE85L
TYZRN1403Z
Q4
TYZRN1403Z
Q6
TY2SC2712G
Q7
TYZRN1403Z
Diodes
Ref#
Description
MFR. Part No.
D1
DIODE (SMD) 1SS355
EDSS00355Y
D6
DIODE (SMD) 1SS355
EDSS00355Y
D7
DIODE (SMD) 1SS355
EDSS00355Y
D8
DIODE (SMD) 1SS355
EDSS00355Y
D9
DIODE (SMD) 1SS355
EDSS00355Y
D10
DIODE (SMD) 1SS355
EDSS00355Y
D11
DIODE (SMD) 1SS355
EDSS00355Y
D12
DIODE (SMD) 1SS355
EDSS00355Y
D13
DIODE (SMD) 1SS355
EDSS00355Y
D15
DIODE (SMD) 1SS355
EDSS00355Y
D14
ZENER DIODE (SMD) RLZ5.6V
EDZD05569Y
Connectors
Ref#
Description
MFR. Part No.
J2
PCB CONNECTOR/S 6P PH=2MM (WHITE)
EX07W48827
J2-40A(J413)
WIRE CONNECTOR/H 6P-6P L=250 PH=2
EX07N49517
J3
PCB CONNECTOR/S 2P PH=2MM
EX07N48223
J3-40A(J412)
WIRE CONNECTOR/H 2P-2P L=250mm PH=2
EX07N48917
J4
EX07N48223
J4-MAIN PCB(J7)
WIRE CONNECTOR/H 2P-2P L=100mm PH=2
EX07N48918
J5
PCB CONNECTOR/S 3P T PH=2.5(WHITE)
EX07N41227
J6
EX07N41216
J6-MAIN PCB(J12)
WIRE CONNECTOR/H 3P-3P L=130MM
EX07N48902
J8
EX07N48331
J8-40A(J411)
WIRE CONNECTOR/H 6P-5P L=250 PH=2
EX07N49518
Hardware
Ref#
Description
MFR. Part No.
SHIELD COVER
MT2100100X
SHIELD HOUSING
MT2100110X
B'T OF SHIELD BOX
MT2100120X
SET SCREW M3x0.5Px6
JS053006MN
FOAM 14x14x2
XZZZ90053Z
110X(x1)
SET SCREW M3x0.5Px4
JS053004MN
PCB(x2)
SET SCREW M3x0.5Px4
JS053004MN
Copyright © 2007 CBTricks.com
