Galaxy DX Radios DX98VHP
EL Driver PCB (EPT91V131Z)
Schematic Diagram
Parts List
Ref#
Description
MFR. Part No.
EL DRIVER PCB EPT91V131Z
#T-149A-P07
EPT91V131Z
EPT91V131Z
Resistors
Ref#
Description
MFR. Part No.
R3
CHIP/F/R (SMD) 0 OHM
RCY060004Z
R4
CHIP/F/R (SMD) 56K OHM
RCY065634Z
R5
CHIP/F/R (SMD) 1K OHM
RCY061024Z
Capacitors
Ref#
Description
MFR. Part No.
C1
CHIP/C 0.47UF 16WV Z Y5V
CK5474AD7R
C2
CHIP/C 0.1UF 50WV K X7R
CK1104AB5X
R1
CHIP/C 0.1UF 25WV Z Y5V
CK2104AD7R
Integrated Circuits
Ref#
Description
MFR. Part No.
IC1
I.C. (SMD) SM8144BV-E2 8PIN
YNSN8144BV
Inductors
Ref#
Description
MFR. Part No.
L1
CHOKE COIL(SMD) 220UH TE
YCTLI2274E
Diodes
Ref#
Description
MFR. Part No.
D1
DIODE (SMD) 1N4148
ED1N04148Y
D2
ZENER DIODE (SMD) RLZ5.1BT6-11
EDZD05519Y
Connectors
Ref#
Description
MFR. Part No.
PCB CONNECTOR/S 5P L=12mm PH=2.5
EX07N48265
WIRE CONNECTOR/H 2P PH=2mm L=50mm
EX07N48539
Hardware
Ref#
Description
MFR. Part No.
FOAM 14x14x2
XZZZ90053Z
SPONGE 15x11x15mm
XZZZ90406Z
SHIELD HOUSING (EL)
MT240N060X
Copyright © 2007 CBTricks.com
