Galaxy
DX Radios DX98VHP
Main
PCB (EPT690010D)
MECHANICAL / CHASSIS:
Ref#
Description |
MFR.
Part No.
DC B+ P.C.B 45.5x11.5x1.6 |
EPT120060A |
C307(MAIN/JP99) |
C/C 0.1UF 50WV SL Z |
CC0501047L |
(Q47/IRF520) |
CC0501047L |
SOLDER PLATE 3.2mm |
XZZZ90002Z |
Hardware
Ref#
Description |
MFR.
Part No.
ANT JACK WITH WIREG (TEFLOW) |
EX06N41258 |
DC ASS'Y (#8 2P) #T-153D-B |
EX07N49508 |
J16-SP |
WIRE CONNECTOR/H 2P L=300MM PH=2.5 |
EX07N48120 |
40A(J403)-METER0 |
WIRE CONNECTOR/H� G2P L=100 PH=2 #28 |
EX07N48233 |
J22-20A(J204) |
WIRE CONNECTOR/H 2P-2P L=160mm PH=2 |
EX07N48921 |
METER(40B-J403)-40A(J401) |
WIRE CONNECTOR/H 2P-2P L=145MM PH=2 |
EX07N48850 |
Q41-VR PCB |
WIRE CONNECTOR/H 2P L=350 PH=2 |
EX07N48964 |
J17-40A(J409) |
WIRE CONNECTOR/H 2P-2P L=400mm |
EX07N49030 |
J7-VR PCB |
WIRE CONNECTOR/H 2P L=280mm PH=2mm |
EX07N48993 |
J10-40A(J419) |
WIRE CONNECTOR/H 2P-2P L=250mm PH=2 |
EX07N48917 |
20A(J202)-METER PCB(40B-J401) |
WIRE CONNECTOR/H 3P-3P L=200 PH=2 |
EX07N49212 |
J11-METER PCB(40B-J404) |
WIRE CONNECTOR/H 3P-3P L=100mm PH=2 |
EX07N48914 |
J18-40A(J415) |
WIRE CONNECTOR/H 3P-3P L=400mm PH=2 |
EX07N49440 |
J6-40A(J408) |
WIRE CONNECTOR/H 3P-3P L=280mm PH=2 |
EX07N48920 |
J21-20A(J203) |
WIRE CONNECTOR/H 4P-4P L=160 PH=2MM |
EX07N49101 |
J5-40A(J402) |
WIRE CONNECTOR/H 5P-5P L=120 PH=2 |
EX07N49210 |
J20-METER PCB(40B-J402) |
EX07N49213 |
J13-40A(J406/J407) (J416/J417) |
WIRE CONNECTOR/H 6P-3P-3P L=120PH=2 |
EX07N49215 |
J9-40A(J416/J417) |
EX07N49216 |
J3-40A(J404) |
WIRE CONNECTOR/H 4P-3P L=320mm PH=2 |
EX07N49511 |
J14-40A(J410) |
WIRE CONNECTOR/H 7P-5P L=120mm PH=2 |
EX07N49510 |
J1-40A(J418)-SW |
WIRE CONNECTOR/H 9P-2P L=150 |
EX07N49211 |
20A(J201)-MAIN PCB |
WIRE CONNECTOR/H 10P L=120mm PH=2mm |
EX07N48910 |
40A(J405)-MOD LED PCB |
WIRE CONNECTOR/H 2P L=210MM PH=2MM |
EX07N49448 |
10A(J3)-MAIN PCB |
WIRE CONNECTOR/H 4P L=310mm PH=2mm |
EX07N49528 |
10A(J5)-MAIN PCB(C290/C272) |
WIRE CONNECTOR/H 2P L=350MM PH=2.5 |
EX07N48212 |
POWER PCB(I/P)(J2) |
CABLE RG-316U 250mm SINGLE SIDE |
WX0412925A |
MAINPCB(ANT) |
WX0412925A |
10A(B-)-MAIN PCB(B-) |
LEAD WIRE #16 250MM BLACK 5:PIN |
WI0025011Q |
10A(B+)-MAIN PCB(B+) |
LEAD WIRE #16 250MM RED 5:PIN |
WI0225011Q |
Hardware
Ref#
Description |
MFR.
Part No.
FRONT PANEL |
PTDX55100A |
FRONT PANEL |
LED WINDOW |
PTDX55090A |
ACRY WINDOW GRAY (54x18x1) |
PT2100031F |
VR (RK097111103E) 20KA/SW 9F L=20 |
RV20303558 |
BAND |
ROTARY SW 8N L=20MM |
EWRT32077S |
HIGH SWR ALERT |
KNOB (A-1) |
PT3600101A |
TALKBACK |
KNOB C-1 |
PT3600120A |
BAND |
KNOB C-1 |
PT3600120A |
VOL/SQ,MIC/RF |
OUTER KNOB |
PT3600170A |
ECHO/TIME |
OUTER KNOB |
PT3600170A |
FINE/COARSE |
OUTER KNOB |
PT3600170A |
DIM/PWR |
OUTER KNOB |
PT3600170A |
VOL/SQ |
INNER KNOB |
PT3600180A |
MIC/RF |
INNER KNOB |
PT3600180A |
ECHO/TIME |
INNER KNOB |
PT3600180A |
FINE/COARSE |
INNER KNOB |
PT3600180A |
DIM/PWR |
INNER KNOB |
PT3600180A |
D SPRING A #6600 |
MT3600080T |
D SPRING B #7800 |
MT3600090T |
D SPRING D #8500 |
MT3600100T |
WIRE BUSHING (ANT) |
PT2970010A |
KNOB WASHER |
PT3600090A |
SW(77S) |
SHIELD PLATE |
BTDX91030A |
PCB CONNECTOR/S 3P PH=2.54 (BLACK) |
EX07N49373 |
DC |
DC IN LABEL 27.2x13.8 |
LZZZ61609A |
ANT LABEL 17.5x9 |
LZZZ61610A |
TOP HOUSING |
MT3600061X |
Bottom Housing(SP) |
SHIELD CLOTH 60x50x0.25t |
LZZZ60084Z |
CLAMP GT-100M |
GZZZ50000Z |
FOAM 15x30x11t |
XZZZ90021Z |
Front panel (4) |
SET SCREW M3x0.5Px6 |
JS033006MN |
Chassis(12) |
JS053006MN |
Main PCB(7) |
SET SCREW T3x6-2mm |
JS053006TN |
SET SCREW M3x0.5Px14 |
DC SOCKET/W |
SET SCREW M3x0.5Px18 |
JS013018MN |
HEAT SINK |
MT2970120A |
HEATSINK COVER |
MT2970141B |
DC FAN 12V DF1204SH |
EX13N46014 |
FAN CLIP |
MT2970110X |
HEAT SINK |
MM7878043B |
HEASINK(x2) |
SET SCREW T3x8-2 |
JS013008TN |
SET CHASSIS |
MT3600310X |
SHIELD COVER |
MT2970150A |
SHIELD CLOTH 10x170x0.3t |
LZZZ60082Z |
SEIELD COVER(PA)(x6) |
JS053006MN |
HEAT SINK (x6) |
SET SCREW M5x0.8Px5 |
JS055005MB |
SET SCREW M2x0.4Px12 |
JS052012MN |
INSULATING PLATE 18x13mm |
XZZZ90020Z |
INSULATING RING |
XZZZ90003Z |
INSULATING PLATE 10x14x1.55mm |
XZZZ90358Z |
AGU FUSE 50A(AT-14000-50) |
EX02N40270 |
TERMINAL BMC8AG |
GZZZ50256Z |
FUSE JACK AT-500 |
GZZZ50258Z |
TERMINAL HOUSING BMC2S-BLOCK |
GZZZ50255Z |
TERMINAL BMC8AG |
GZZZ50256Z |
Copyright � 2007 CBTricks.com
Disclaimer: Although the greatest care has been taken while compiling
these documents,
