Galaxy DX Radios DX98VHP
PLL Alignment
See Alignment Locations
SETTINGS CONNECTION
ADJUST
ADJUST FOR
10.240 MHz PLL REFERENCE:
RX Mode, AM,
Band E, Ch. 1
Connect Frequency counter to IC3 Pin 4.
Check for 10.2400MHz ± 200 Hz. If tolerance is beyond this, replace X1 (10.240MHz).
VCO VOLTAGE:
RX Mode, AM,
Band E, CH. 1
Connect DC voltmeter to TP2
L14
Adjust for 2.75 VDC ±0.1
VCO OUTPUT:
RX Mode, AM,
Band E, CH. 1
Connect scope to TP3
L15
Adjust for max. RF
PLL MIXER OSCILLATOR:
RX Mode, AM,
Band E, CH. 1
Set Fine and coarse clarifier control to 12 oclock position.
Set clarifier switch to RX/TX
Connect Frequency Counter to TP3.
L20
AM: Adjust for
16.2700MHz ±20 Hz.
L21
USB: Adjust for
16.2725MHz ±20 Hz.
L22
LSB: Adjust for
16.2675MHz ±20 Hz.
TX OFFSET FREQUENCY:
Set mode to LSB RX
VR7
Key TX; Adjust for
16.2675MHz ±20 Hz.
FREQUENCY COUNTER:
Set mode to AM RX
Band E, CH.1
VC201 on Ch Sel PCB (EPT99HP20A)
Adjust VC201 on channel selector PCB for correct reading on frequency display.
Copyright © 2007 CBTricks.com
