Galaxy
DX Radios DX98VHP
RF AMP PCB (EPAC40010A)
PCB Layout
Trace Layout Top
Trace Layout Bottom
Schematic
Diagram
Resistors
Ref#
Description |
MFR.
Part No.
R1 |
CHIP/F/R (SMD) 10K OHM 1/2W |
RCY051034Z |
R2 |
CHIP/F/R (SMD) 82 OHM 0.1W |
RCY018204Z |
R3 |
RCY018204Z |
R4 |
CHIP/F/R (SMD) 10K OHM 0.1W |
RCY011034Z |
R5 |
RCY011034Z |
R6 |
CHIP/F/R (SMD) 100 OHM 0.1W |
RCY011014Z |
R7 |
CHIP/F/R (SMD) 1K OHM 0.1W |
RCY011024Z |
R8 |
RCY011034Z |
R10 |
CHIP/F/R (SMD) 1K OHM 1/2W |
RCY051024Z |
R11 |
RCY051024Z |
R12 |
CHIP/F/R (SMD) 2.2KOHM 1/4W |
RCY142224Z |
R13 |
RCY011034Z |
R14 |
CHIP/F/R (SMD) 47K OHM 0.1W |
RCY014734Z |
R15 |
RCY051034Z |
R17 |
CHIP/F/R (SMD) 2.2K OHM 0.1W |
RCY012224Z |
R18 |
RCY011024Z |
R19 |
RCY011034Z |
R20 |
CHIP/F/R (SMD) 10 OHM 0.1W |
RCY011004Z |
R21 |
RCY011004Z |
R22 |
CHIP/F/R (SMD) 1K OHM 1/4W |
RCY141024Z |
R23 |
RCY141024Z |
R24 |
RCY141024Z |
R25 |
CHIP/F/R (SMD) 47K OHM 1/4W |
RCY144734Z |
R26 |
RCY144734Z |
R27 |
M/O/R 100 OHM 2W P |
RFP201014Z |
R28 |
RFP201014Z |
R29A |
M/O/R 100 OHM 2W P (Feed Back PCB (EPA010030A)) |
RFP201014Z |
R29B |
RFP201014Z |
R30A |
RFP201014Z |
R30B |
RFP201014Z |
R31 |
RCY141024Z |
R32 |
RCY141024Z |
R33 |
RCY141024Z |
R34 |
RCY144734Z |
R35 |
RCY144734Z |
R36 |
RCY011024Z |
R37 |
RCY011024Z |
R38 |
RCY011024Z |
R39 |
RCY011034Z |
Ref#
Description |
MFR.
Part No.
VR1 |
S/F/R (SMD) 5 (TMC3K) |
RE502Y0129 |
VR2 |
RE502Y0129 |
VR3 |
RE502Y0129 |
Capacitors
Ref#
Description |
MFR.
Part No.
C1 |
CHIP/C 0.01UF 500WV K X7R |
CK3103AA5X |
C2 |
CK3103AA5X |
C5 |
CHIP/C 0.01UF 50WV K X7R |
CK1103AB5X |
C6 |
CK1103AB5X |
C7 |
CK1103AB5X |
C8 |
CK1103AB5X |
C9 |
CHIP/C 0.1UF 50WV K X7R |
CK1104AB5X |
C10 |
CK1104AB5X |
C11 |
CHIP/C 82PF 500WV J CH |
CK3820AA4A |
C12 |
CHIP/C 39PF 500WV J CH |
CK3390AA4A |
C13 |
CHIP/C 150PF 500WV J CH |
CK3151AA4A |
C14 |
CHIP/C 12PF 500WV J CH |
CK3120AA4A |
C15 |
CK3820AA4A |
C16 |
CK3103AA5X |
C18 |
CK3103AA5X |
C19 |
CK1104AA5X |
C20A |
CHIP/C 680PF 500WV J CH |
CK3681AA4A |
C20B |
CK3681AA4A |
C21 |
CK1104AA5X |
C22 |
CK1104AA5X |
C24 |
T/C (SMD) ('A'CASE) K 2.2 UF 16WV M |
CTY162256Z |
C25 |
CK1104AB5X |
C26 |
CK1104AB5X |
C27 |
CK1104AB5X |
C28 |
CK1104AB5X |
C29 |
CK1104AB5X |
C30 |
CK1104AB5X |
C31 |
CK1104AB5X |
C32 |
CK1104AB5X |
C33 |
CK1104AB5X |
C34 |
CK1103AA5X |
C36 |
CK1103AA5X |
C39 |
E/C 470UF 25WV Z |
CE0254777Z |
C40 |
CK1104AB5X |
C41 |
CK1104AB5X |
C42 |
CK1104AB5X |
C45 |
CK1104AB5X |
C46 |
CK1104AB5X |
C47 |
CK1103AA5X |
C49 |
CK1103AA5X |
C50 |
CK1104AB5X |
C52A |
CHIP/C 0.01UF 100WV K X7R (Feed Back PCB (EPA010030A)) |
CK4103AA5X |
C52B |
CK4103AA5X |
C53A |
CK4103AA5X |
C53B |
CK4103AA5X |
C55 |
CK1104AB5X |
C56 |
CK1104AB5X |
C57 |
CK1104AB5X |
C58 |
E/C 470UF 25WV Z |
CE0254777Z |
C60 |
CK1104AB5X |
C61 |
CK1104AB5X |
C62 |
CK1104AB5X |
C63 |
CHIP/C 68PF 500WV J CH |
CK3680AA4A |
C64 |
CK1104AB5X |
C65 |
CK1104AB5X |
C66 |
CK1104AB5X |
C67 |
CK1104AB5X |
C68 |
CK1104AB5X |
C69 |
CK1104AB5X |
C70 |
CK1104AB5X |
C71 |
CK1104AB5X |
C72 |
CK1104AB5X |
C73 |
CK1104AB5X |
C74 |
E/C 10UF 50WV Z |
CE0501067Z |
Transistors
Ref#
Description |
MFR.
Part No.
Q1 |
T/R (SMD) 2SC2712GR-TE85L |
TY2SC2712G |
Q2 |
TY2SC2712G |
Q3 |
T/R (SMD) 2SD999-TP |
TY2SD0999Z |
Q4 |
TY2SC2712G |
Q5 |
T/R (SMD) 2SB798DL-(T1) |
TY2SB0798Z |
Q6 |
T/R IRF520 |
TIRF00520Z |
INSULATING RING |
XZZZ90003Z |
INSULATING PLATE 10x14x1.55mm |
XZZZ90358Z |
SET SCREW� M2x0.4Px10 |
JS052010MN |
Q7 |
T/R IRF520 |
TIRF00520Z |
INSULATING RING |
XZZZ90003Z |
XZZZ90358Z |
JS052010MN |
Q8 |
T/R IRF520 |
TIRF00520Z |
INSULATING RING |
XZZZ90003Z |
XZZZ90358Z |
JS052010MN |
Q9 |
T/R IRF520 |
TIRF00520Z |
INSULATING RING |
XZZZ90003Z |
XZZZ90358Z |
JS052010MN |
Q10 |
T/R IRF520 |
TIRF00520Z |
INSULATING RING |
XZZZ90003Z |
XZZZ90358Z |
JS052010MN |
Q11 |
T/R IRF520 |
TIRF00520Z |
INSULATING RING |
XZZZ90003Z |
XZZZ90358Z |
JS052010MN |
Q12 |
T/R IRF520 |
TIRF00520Z |
INSULATING RING |
XZZZ90003Z |
XZZZ90358Z |
JS052010MN |
Q13 |
T/R IRF520 |
TIRF00520Z |
INSULATING RING |
XZZZ90003Z |
XZZZ90358Z |
JS052010MN |
Diodes
Ref#
Description |
MFR.
Part No.
D1 |
DIODE (SMD) MA728 -(TX) |
EDMA00728Y |
D2 |
DIODE (SMD) 1SS355 |
EDSS00355Y |
D3 |
DIODE (SMD) 1N4148 |
ED1N04148Y |
D4 |
LED (SMD) KP-3216ID (RED) |
EX01Y40141 |
D5 |
ED1N04148Y |
D7 |
ZENER DIODE (SMD) K0.5W 8.2V (RLZ) |
EDZD05829Y |
D8 |
ZENER DIODE (SMD) KRLZ5.6V |
EDZD05569Y |
D9 |
EDZD05569Y |
D10 |
DIODE LT6A400 |
EDLT6A400Z |
D11 |
DIODE LT6A400 |
EDLT6A400Z |
Thermistor
Ref#
Description |
MFR.
Part No.
TH1 |
THERMISTOR (SMD) (2K) KNSM2202J410J3R |
RTU142024Y |
Inductors
Ref#
Description |
MFR.
Part No.
L1 |
SPRING COIL AC 1.2x9x5.5 |
ECSPG18422 |
L2 |
ECSPG18422 |
L3 |
BEAD FERRITE COIL WB-403025 |
YCBAD18581 |
L4 |
YCBAD18581 |
L5 |
YCBAD18581 |
L6 |
YCBAD18581 |
L7 |
CHOKE COIL (SMD) 100UH TF J |
YCTLI1073F |
Transformers
Ref#
Description |
MFR.
Part No.
T1 |
RF COIL ASS'Y #ST182E2 (3t)�� |
ECRFZ10184 |
T2 |
RF COIL ASS'Y #T140L7 (4t) |
ECRFZ10230 |
T3 |
RF COIL ASS'Y #ST182E2 (3t) |
ECRFZ10184 |
T4 |
ECRFZ10230 |
T5 |
RF COIL GSTC50265TS02 |
ECRFZ10231
T6 |
ECRFZ10231
Relay
Ref#
Description |
MFR.
Part No.
RL1 |
RELAY JW2SN-12V(AJW7211) |
EX05N40854 |
Connectors
Ref#
Description |
MFR.
Part No.
J3 |
PCB CONNECTOR/S 4P PH=2MM |
EX07N48490 |
J4 |
PCB CONNECTOR/S 2P PH=2.5 L=14.2 |
EX07N48152 |
J5 |
PCB CONNECTOR/S��� 2P PH=2.5 |
EX07N41226 |
J7 |
EX07N48152 |
DC (x4), |
C PIN AC 220V |
GZZZ50011Z |
#16 |
C PIN AC 220V |
GZZZ50011Z |
J2(I/P) |
A TYPE JACK (R PIN) TMP-J01X-A2 |
GZZZ50063Z |
Ref#
Description |
MFR.
Part No.
FS1 |
FUSE 30A |
EX02N40271 |
FS1(x2) |
FUSE JACK CQ-111(PF) |
GZZZ50253Z |
FS2 |
FUSE 30A |
EX02N40271 |
FS2(x2) |
GZZZ50253Z |
Hardware
Ref#
Description |
MFR.
Part No.
POWER PCB(x4) |
SET SCREW M3x0.5Px6 |
JS053006MN |
