Galaxy
DX Radios DX98VHP
VR PCB (EPT99HP40A)
Trace Layout
Parts List
Ref#
Description |
MFR.
Part No.
VR PCB (DX-98VHP) EPT99HP40A |
#T-149E-P09 |
EPT99HP40A |
EPT99HP40A |
Resistors
Ref#
Description |
MFR.
Part No.
R401 |
CHIP/F/R (SMD) 47 OHM 0.1W |
RCY014704Z |
R402 |
CHIP/F/R (SMD) 100K OHM 0.1W |
RCY011044Z |
R403 |
CHIP/F/R (SMD) 1K OHM 0.1W |
RCY011024Z |
R404 |
CHIP/F/R (SMD) 220K OHM 0.1W |
RCY012244Z |
R405 |
CHIP/F/R (SMD) 4.7K OHM 0.1W |
RCY014724Z |
R406 |
CHIP/F/R (SMD) 470K OHM 0.1W |
RCY014744Z |
R407 |
CHIP/F/R (SMD) 10K OHM 0.1W |
RCY011034Z |
R408 |
CHIP/F/R (SMD) 39K OHM 0.1W |
RCY013934Z |
R409 |
CHIP/F/R (SMD) 0 OHM 0.1W |
RCY010004Z |
Capacitors
Ref#
Description |
MFR.
Part No.
C401 |
CHIP/C 4.7UF 16WV Z Y5V |
CK5475AA7R |
C402 |
CK5475AA7R |
C403 |
CHIP/C 2.2UF 16WV Z Y5V |
CK5225AB7R |
C404 |
CK5225AB7R |
Diodes
Ref#
Description |
MFR.
Part No.
D401 |
DIODE (SMD) 1SS355 |
EDSS00355Y |
D402 |
EDSS00355Y |
Potentiometers
Ref#
Description |
MFR.
Part No.
(VOL/SQ) VR401 |
VR (RK097221101K) 50KB/50KA W/SW |
RV50303522 |
(MIC/RF) VR402 |
VR (RK097221002E) 1KB/1KA |
RV10203524 |
(DIM/POWER) VR403 |
VR 5KB/5KB W/SW |
RV50203538 |
(ECHO/TIME) VR404 |
V/R L=30 50KA/50KA |
RV50303620 |
(FINE/COARSE) VR405 |
VR 20KB/1KB |
RV20303556 |
VR406 |
S/F/R (SMD) 2K (TMC3K) |
RE202Y0186 |
Transistors
Ref#
Description |
MFR.
Part No.
Q401 |
T/R (SMD) 2SC2712GR-TE85L |
TY2SC2712G |
Q402 |
TY2SC2712G |
Q403 |
TY2SC2712G |
Connectors
Ref#
Description |
MFR.
Part No.
J401 |
PCB CONNECTOR/S 2P PH=2MM |
EX07N48223 |
J402 |
PCB CONNECTOR/S 5P PH=2MM (WHITE) |
EX07W48826 |
J403 |
EX07N48223 |
J404 |
PCB CONNECTOR/S 3P PH=2MM |
EX07N48350 |
J405 |
EX07N48223 |
J406 |
PCB CONNECTOR/S 3P PH=2MM (WHITE) |
EX07W48824 |
J407 |
EX07N48350 |
J408 |
EX07N48350 |
J409 |
EX07N48223 |
J410 |
PCB CONNECTOR/S 5P PH=2MM |
EX07N48222 |
J411 |
EX07N48222 |
J412 |
EX07N48223 |
J413 |
PCB CONNECTOR/S 6P PH=2 |
EX07N48331 |
J416 |
EX07N48350 |
J415 |
EX07W48824 |
J417 |
EX07W48824 |
J418 |
EX07N48223 |
J419 |
EX07N48223 |
