Galaxy DX Radios DX99V
Band Board Layout (EPT004410Z)
Schematic Diagram
Ref#
Description
MFR. Part No.
BAND PCB 82x50x1.6t
EPT004410Z
Resistor Array
Ref#
Description
MFR. Part No.
RA1
RESISTOR ARRAY 47K 8P
RCS0870014
RA2
RCS0870014
RA3
RCS0870014
Resistors
Ref#
Description
MFR. Part No.
R6
C/F/R 47K OHM 1/4W U
RCU144734Z
R7
RCU144734Z
R8
RCU144734Z
R9
RCU144734Z
Capacitors
Ref#
Description
MFR. Part No.
C1
E/C 220UF 10WV Z
CE0102277Z
C2
C/C 0.01UF 50WV SL Z
CC0501037L
Integrated Circuits
Ref#
Description
MFR. Part No.
IC1
I.C. TC4008B 16PIN (TOSHIBA)
ENTA04008B
IC2
ENTA04008B
Diodes
Ref#
Description
MFR. Part No.
D4-36
DIODE 1N4148
EDIN04148Z
Connectors
Ref#
Description
MFR. Part No.
J1
PCB CONNECTOR/S 12P T
EX07N41309
J1
WIRE CONNECTOR/H 12P
EX07N48484
J2
PCB CONNECTOR/S 9P T
EX07N48083
J2
WIRE CONNECTOR/H 9P-9P
EX07N48483
J3
PCB CONNECTOR/S 7P T
EX07N48167
J3
WIRE CONNECTOR/H 7P L=290mm
EX07N48759
Jumper Wire
Ref#
Description
MFR. Part No.
J4
JUMPER WIRE 7x6x7mm
WX01070706
J5
JUMPER WIRE 7x15x7mm
WX01070715
J6
JUMPER WIRE 7x8x7mm
WX01070708
J7
JUMPER WIRE 7x7x7mm
WX01070707
J8
JUMPER WIRE 7x4x7mm
WX01070704
J9
JUMPER WIRE 7x9x7mm
WX01070709
J10
JUMPER WIRE 7x5x7mm
WX01070705
J11
JUMPER WIRE 7x4x7mm
WX01070704
J12
JUMPER WIRE 7x9x7mm
WX01070709
J13
JUMPER WIRE 7x8x7mm
WX01070708
J14
JUMPER WIRE 7x9x7mm
WX01070709
J15
JUMPER WIRE 7xl3x7mm
WX01070713
J16
WX01070713
J17
JUMPER WIRE 7x11x7mm
WX01070711
J18
WX01070711
J19
JUMPER WIRE 7x10x7mm
WX01070710
J20
WX01070711
Copyright © 1998,1999,2000 CBTricks.com
