Galaxy DX Radios DX99V
Channel Selector PCB (EPT055V30Z)
Copper Trace Layout
Ref#
Description
MFR. Part No.
CH SW P.C.B. EPT055V30Z Complete with Components
#MT-140P-P04
CH SW P.C.B.
EPT055V30Z
Resistors
Ref#
Description
MFR. Part No.
R312
C/F/R 1K OHM 1/4W M
RCM141024A
R313
C/F/R 1K OHM 1/4W M
RCM141024A
R314
C/F/R 1K OHM 1/4W U
RCU141024Z
R315
C/F/R 470 OHM 1/4W M
RCM144714B
R316
C/F/R 1K OHM 1/4W M
RCM141024A
R317
C/F/R 1K OHM 1/4W M
RCM141024A
R318
C/F/R 1K OHM 1/4W M
RCM141024B
R319
C/F/R 1K OHM 1/4W M
RCM141024A
R320
C/F/R 1K OHM 1/4W M
RCM141024B
R321
C/F/R 1K OHM 1/4W M
RCM141024A
R322
C/F/R 1K OHM 1/4W M
RCM141024A
R323
C/F/R 1K OHM 1/4W M
RCM141024A
R324
C/F/R 1K OHM 1/4W U
RCU141024Z
D312
C/F/R 0 OHM 1/4W P
RCP140004Z
Connectors
Ref#
Description
MFR. Part No.
J304
PCB CONNECTOR/S 9P T
EX07N48083
J306
PCB CONNECTOR/S 12P PH=2(WHITE)
EX07N48767
J306
WIRE CONNECTOR/H 12P-12P L=100 PH=2
EX07W49252
J307
EX07N48150
J307
WIRE CONNECTOR/H 12P-12P L=120 PH=2
EX07W49253
Jumper Wire
Ref#
Description
MFR. Part No.
J302
JUMPER WIRE 7x3x7mm
WX01070703
J303
C/F/R 0 OHM 1/4W P
RCP140004Z
J323
JUMPER WIRE 7x3x7mm
WX01070703
J325
JUMPER WIRE 7x3x7mm
WX01070703
J326
JUMPER WIRE 7x3x 7mm
WX01070703
D311
JUMPER WIRE 7x8x7mm
WX01070708
D313
JUMPER WIRE 7x8x7mm
WX01070708
D314
JUMPER WIRE 7x8x7mm
WX01070708
D315
JUMPER WIRE 7x8x7mm
WX01070708
D316
JUMPER WIRE 7x8x7mm
WX01070708
D324
JUMPER WIRE 7x8x7mm
WX01070708
Switch
Ref#
Description
MFR. Part No.
ROTARY SW GPS-0501
EWRT32000S
