Galaxy DX Radios DX99V
CHASSIS PARTS
Ref. No.
Description
MFR. Part No.
VOL/SQUELCH
V/R 50KA/50KB W/SW
RV50303433
DIMMER/RF POWER
V/R 1KB/1KA W/SW
RV10203434
FINE/COURSE CLARIFIER
V/R 20KB/1KB
RV20303557
MIC / RF GAIN
V/R 1KB/1KA
RV10203438
ECHO/TIME
VR 50KA/50KA W/SW
RV50303520
MODE SWITCH
ROTARY SW
EWRT32002S
BAND SWITCH
ROTARY SW
EWRT32008S
SPEAKER 8ohm 3W 3.5in
ES300835SQ
DC CORD W/FUSE SOCKET
WA0012185A
SIGNAL METER P-48-8935
EX03N40462
MICROPHONE ASSY BLACK DMC507-012
EX04N40002
ANT JACK
EX06T41019
EAR JACK 3.5mm (2)
EX06N41045
DC JACK 3P
EX06T40007
DIODE LT6A400
EDLT6A400Z
FUSE 16V 7A
EX02N40210
FRONT PANEL
PTDX55010A
KNOB WASHER
PT3600090A
ACRY WINDOW ORANGE Counter
PT2100030B
CH DISPLAY WINDOW
PTDX55020A
KNOB Rotate SW (A-1)
PT3600101A
KNOB B-1(CHROM) Dual VR(INNER)
PT3600110A
KNOB Single VR
PT3600120A
KNOB D-1(CHROM) Dual VR(OUTER)
PT3600130A
FRONT CHASSIS DX-99V
MTDX55032X
SW CHASSIS
MTDX55042X
SET CHASSIS W/NUT
MT3001021X
HANDLER
MT3600030S
DC SOCKET HOLDER
MT360005OX
TOP HOUSING
MT3600061X
BOTTOM HOUSING
MT3600071X
D SPRING A #6600 ROTATE SW
MT3600080T
D SPRING B #7800 DUAL VR (INNER)
MT3600090T
D SPRING D #8500 DUAL VR (OUTER)
MT3600100T
HEAT SINK OUT SIDE
MM7878041B
PCB BRACKET
MT3001010S
MIC PLATE Galaxy
BA0112010A
ID PLATE
BTDX55030A
SER NO LABEL
LZZZ61307Z
QC LABEL
LZZZ61009Z
SHIELD CLOTH Top &. Bottom Housing 10x88x0.3t
LZZZ6000lZ
PCs
CLAMP
GZZZ50000Z
MASK PLATE(SW) SLIDE SW
XZZZ90296Z
FOAM 15x30xllt
XZZZ90021Z
INSULATING RING TR43,44,56
XZZZ90003Z
INSULATING PLATE 18x13mm
XZZZ9002OZ
INSULATING PLATE 10xl4xl.55mm
XZZZ90358Z
SOLDER PLATE
XZZZ90098Z
TUBE 1.2x6mm
WX0012006A
TUBE 1.2x10mm
WX0012010A
TUBE 1.2xl3mm
WX0012013A
TUBE 3.3xl5mm
WX0033015B
IC SHIELD B
LZZZ61008Z
PCB STOPPER
XZZZ90006Z
SHIELD PLATE (A)
PT1200020A
SHIELD PLATE (A)
MT1200060N
SHIELD PLATE
MT271006OX
SET SCREW T3x8-2 STEEL
JS013008TH
SET SCREW M2x0.4Px6 TR41
JS052006MN
SET SCREW M3x0.5Px6 Front panel (4)
JS033006MN
SET SCREW M3x0.5Px6 CH(2) Chassis(14)
JS053006MN
SET SCREW M2x0.4Px10 Trs-1
JS05201OMN
SET SCREW M3x0.5Px8 Speaker(4),DC SOCKET(2)
JS053008MN
SET SCREW M2x0.4Pxl2 TR43,44,56
JS052012MN
SET SCREW T3x6-2 Main PCB(5)
JS053006TN
SET SCREW T3x8-2 Heatsink(2)
JS013008TN
SET SCREW M3x0.5Px6
JS013006MV
NUT WITH WASHER M3x3.5t
JN263035ZS
SET SCREW M2.6x0.45Px4 SLIDE SW(10)
JS052604MN
SET SCREW T2.6x6-2 STEEL METER PCB(4)
JS052606TH
PVC BAG 600x410x830x0.07t
UB07604183
PVC BAG 290x450x0.05tmm
UB052945ZZ
BUBBLE SHEET
UF106025ZZ
STOPPER
UDT360003Z
ACCESSORY BOX
UDT360002Z
MAIN UNIT BOARD
UDT360OOlZ
CARTON DX99V
UCT2101A6G
G/B DX-99V
UGT2101AIG
I/M
AT210101OG
MIC STOPPER
XZZZ90008Z
MOUNTING SCREW BLACK (4)
XZZZ90007Z
SET SCREW W5x10-1
JS015010WH
SET SCREW T3.5x8-2 (3)
JS013508TH
OUT-TOOTH WASHER 5.5xlOx0.3tmm (4)
JW31551OCN
IN-TOOTH WASHER 4x8x0.3tmm (3)
JW324008CN
FIBER WASHER (4)
XZZZ90188Z
PVC BAG DC Cord 70x250x0.05tmm
UB050725ZZ
PVC BAG 100X150X0.05tmm Spare Parts
UB051015ZZ
PVC BAG 160x250x0.05tmm I/M (1) Mic(1)
UB051625ZZ
SSSEB51H K905 271X 1219x0.8(SECC)0.15 (23)
HZZZ76005Z
Copyright © 1998,1999,2000 CBTricks.com
