Galaxy DX Radios "Galaxy Plus"
Echo PCB (EPT0SSB50B) Board Layout
Schematic Diagram
Ref#
Description
MFR. Part No.
ECHO P.C.B. EPT0SSB50B
#T-118C-P02
ECHO P.C.B. 98x80x1.6tmm (S)
EPT0SSB50B
Potentiometers
Ref#
Description
MFR. Part No.
VR1
S/F/R VM6CK PV(1S) B50K
RE50300056
Resistors
Ref#
Description
MFR. Part No.
R1
C/F/R� F-TYPE 1K OHM 1/4W U
RCU141024Z
R2
C/F/R 39K OHM 1/4W U
RCU143934Z
R3
C/F/R F-TYPE 100K OHM 1/4W U
RCU141044Z
R4
C/F/R 100K OHM 1/4W M
RCM141044A
R5
C/F/R 100 OHM 1/4W M
RCM141014B
R6
C/F/R F-TYPE 100 OHM 1/4W U
RCU141014Z
R7
C/F/R 120K OHM 1/4W U
RCU141244Z
R8
RCU141244Z
R9
RCU141244Z
R10
RCU143934Z
R11
RCU141244Z
R13
RCU141044Z
R14
C/F/R 47K OHM 1/4W U
RCU144734Z
R16
RCU143934Z
R17
RCU141244Z
R18
RCU141044Z
R19
RCU141044Z
R20
C/F/R 68K OHM 1/4W U
RCU146834Z
R21
RCU141024Z
R22
RCU143934Z
R23
RCU143934Z
R24
RCU143934Z
R25
RCU143934Z
R26
RCU141244Z
R27
RCU143934Z
R28
RCU144734Z
R29
RCU141014Z
R30
RCU144734Z
R31
C/F/R F-TYPE 4.7K OHM 1/4W U
RCU144724Z
R32
RCU141244Z
R33
RCU141244Z
R34
RCU141024Z
R35
RCU141014Z
R41
RCU141024Z
Capacitors
Ref#
Description
MFR. Part No.
C1
E/C 2.2UF 50WV Z
CE0502257Z
C2
C/C 0.001UF 50WV SL Z
CC0501027L
C3
C/C 0.1UF 50WV SL Z
CC0501047L
C4
E/C 47UF 10WV Z
CE0104767Z
C5
C/C 220PF 50WV SL K
CC0502215L
C6
E/C 2.2UF 50WV Z
CE0502257Z
C7
M/C 0.0033UF 50WV K
CM0503325Z
C8
E/C 2.2UF 50WV Z
CE0502257Z
C9
E/C 47UF 10WV Z
CE0104767Z
C10
C/C 220PF 50WV SL K
CC0502215L
C11
M/C 0.0033UF 50WV K
CM0503325Z
C12
M/C 0.0033UF 50WV K
CM0503325Z
C13
C/C 220PF 50WV SL K
CC0502215L
C14
E/C 2.2UF 50WV Z
CE0502257Z
C15
E/C 2.2UF 50WV Z
CE0502257Z
C16
M/C 0.0033UF 50WV K
CM0503325Z
C17
M/C 0.0033UF 50WV K
CM0503325Z
C18
M/C 0.0033UF 50WV K
CM0503325Z
C19
C/C 220PF 50WV SL K
CC0502215L
C20
E/C 2.2UF 50WV Z
CE0502257Z
C21
E/C 10UF 25WV Z
CE0251067Z
C22
M/C 0.001UF 50WV K
CM0501025Z
C23
E/C 2.2UF 50WV Z
CE0502257Z
C24
E/C 2.2UF 50WV Z
CE0502257Z
C25
E/C 2.2UF 50WV Z
CE0502257Z
C28
E/C 220UF 16WV Z
CE0162277Z
C30
E/C 47UF 10WV Z
CE0104767Z
C31
CC0501027L
C32
CC0501027L
C33
C/C 0.1UF 50WV SL Z
CC0501047L
C34
C/C 0.1UF 50WV SL Z
CC0501047L
C35
C/C 0.1UF 50WV SL Z
CC0501047L
C36
M/C 0.0033UF 50WV K
CM0503325Z
Diodes
Ref#
Description
MFR. Part No.
D1
DIODE 1N4148
ED1N04148Z
Integrated Circuits
Ref#
Description
MFR. Part No.
IC1
I.C.(SONY) CXA4558P
ENSO04558P
IC2
I.C.(JRC) NJM324D 14PIN
ENJR00324D
IC3
I.C.(MATSUSHITA) MN3008���� 8PIN
ENMA03008Z
IC4
I.C.(MATSUSHITA) MN3101���� 8PIN
ENMA03101Z
Connectors
Ref#
Description
MFR. Part No.
J1
PCB CONNECTOR/S 3P T PH=2.5
EX07N41216
J1
WIRE CONNECTOR/H 3P-3P L=130MM
EX07N48820
J2
PCB CONNECTOR/S 3P T PH=2.5(WHITE)
EX07N41227
J3
PCB CONNECTOR/S 6P T PH=2.5
EX07N41266
J3
WIRE CONNECTOR/H 6P L=250mm PH=2.5
EX07N48446
J4
PCB CONNECTOR/S 2P T PH=2.5(WHITE)
EX07N41330
J4
WIRE CONNECTOR/H 2P L=180MM
EX07N48041
J5
PCB CONNECTOR/S 2P PH=2.5
EX07N41226
J5
WIRE CONNECTOR/H 2P L=250mm
EX07N48279
Jumper Wire
Ref#
Description
MFR. Part No.
J6
JUMPER WIRE 7x5x7mm
WX01070705
J7
JUMPER WIRE 7x5x7mm
WX01070705
J8
JUMPER WIRE 7x10x7mm
WX01070710
J9
WX01070710
J10
JUMPER WIRE 7x5x7mm
WX01070705
J11
JUMPER WIRE 7x5x7mm
WX01070705
