Northpoint NT6HP
Northpoint NT4HP Frequency Conversion Instructions:
1.
Check out the radio for proper operation before starting.
2.
Remove Power from the radio
3.
Remove the bottom cover. (speaker side)
4.
With radio open, knobs facing you, locate the frequency board in lower left section of chassis.
On the top right of the frequency board, there are two soldered jumpers next to the CQ8.0000 crystal.
Open the jumper furthest from you.
5.
Locate J106 directly behind the echo control, (3 pins with a jumper on the right pair). Move the jumper to the left pair of pins.This completes the frequency conversion.
6.
Apply Power and check out the radio for proper operation and do or check alignment if necessary.
You now have a choice of 6 bands.
To select band, Move BRT/DIM switch to the DIM position. Select N4, or band 4, There are 6 bands. Move the BRT/DIM switch back to BRT. This selects the "CB" band CH. 1 - CH. 40.
See frequency chart.
7.
Replace cover.
Peak & Tune
Set dead key power levels for 10 watts high power (VR13).Set VR14 for 100% modulation +/- 2%. This concludes the peak & tune for optimum performance of the Northpoint NT-4 and 6 series radio.
Copyright © 2006 CBTricks.com
