Ranger RCI-2950
CPU PCB (EPT295043Z)
Trace Layout
Resistors Array
Ref#
Description
MFR. Part No.
RA601
RESISTOR ARRAY, 10K/20K 6P
RCS0670023
RA602
RESISTOR ARRAY, 47K 5P
RCS0570009
RA603
RCS0570009
RA604
RESISTOR ARRAY, 220K 5P
RCS0570022
RA605
RCS0570009
RA606
RESISTOR ARRAY, 220K 9P
RCS0970021
RA607
RESISTOR ARRAY, 47K 9P
RCS0970015
RA608
RESISTOR ARRAY, 47K 7P
RCS0770020
RA609
RCS0570009
RA610
RCS0570022
RA611
RCS0570009
Resistors
Ref#
Description
MFR. Part No.
R601
270ohm 1/4W (U) TYPE, CARBON
RCU142714Z
R602
220ohm 1/4W (U) TYPE, CARBON
RCU142214Z
R603
180ohm 1/4W (U) TYPE, CARBON
RCU141814Z
R604
82ohm 1/4W (U) TYPE, CARBON
RCU148204Z
R605
470ohm .1 W CHIP
RCY014714Z
R606
470ohm .1W CHIP
RCY014714Z
R607
470ohm .1W CHIP
RCY014714Z
R608
470ohm .1 W CHIP
RCY014714Z
R609
10ohm .1 W, CHIP
RCY011034Z
R610
1ohm .1 W CHIP
RCY011024Z
R611
47K, 0.1W CHIP
RCY014734Z
R612
47K, 0AW CHIP
RCY014734Z
R613
47K, 0.1W CHIP
RCY014734Z
R614
47K, 0.1 W CHIP
RCY014734Z
R615
47K, 0.1W CHIP
RCY014734Z
R617
47K, 0.1W CHIP
RCY014734Z
R618
47K, 0.1 W CHIP
RCY014734Z
R619
47K,.0.1W CHIP
RCY014734Z
R620
470ohm .1W CHIP
RCY014714Z
R621
47K 0.1W CHIP
RCY014734Z
R622
47K 0.1 W CHIP
RCY014734Z
R623
47K 0.1W CHIP
RCY014734Z
R624
47K 0.1 W CHIP
RCY014734Z
R625
47K 0.1W CHIP
RCY014734Z
R626
4.7K 0.1 W CHIP
RCY014724Z
R627
47K 0.1W CHIP
RCY014734Z
R628
47K 0.1 W CHIP
RCY014734Z
R629
47K 0.1W. CHIP
RCY014734Z
R630
RESISTOR, 1MEG, 0.1 W, CHIP
RCY011054Z
R631
10ohm .1 W CHIP
RCY011034Z
R632
47K 0.1 W CHIP
RCY014734Z
R633
39K 0.1 W CHIP
RCY013934Z
R634
RESISTOR, 220K 0.1 W CHIP
RCY012244Z
R635
RESISTOR, 1MEG 0.1W CHIP
RCY011054Z
R636
RESISTOR, 100K 0.1W CHIP
RCY011044Z
R637
RESISTOR, 220K 0.1W CHIP
RCY012244Z
R638
RCY011044Z
R639
RESISTOR, 47K 0.1W CHIP
RCY014734Z
R640
RCY014734Z
R641
RCY014734Z
R642
RCY014734Z
R643
RCY014734Z
R644
RCY014734Z
R645
RCY014734Z
R646
RESISTOR, 47K O.1W CHIP
RCY014734Z
R647
RCY014734Z
R648
RCY014734Z
R649
RCY014734Z
R650
RCY014734Z
R651
RCY014734Z
R652
RESISTOR, 47 K 0.1W CHIP
RCY014734Z
R653
RCY014734Z
R654
RCY014734Z
R655
RCY014734Z
R656
RCY014734Z
R657
RCY014734Z
R658
RCY014734Z
R659
RCY014734Z
R660
RCY014734Z
R661
RCY014734Z
8662
RCY014734Z
Capacitors
Ref#
Description
MFR. Part No.
C601
.01uF 50WV K Z5U, MONO.
CK1103AB7U
C602
.1uF 35WV M, TANTALUM
CTY351046Z
C603
.33uF 35WV M, TANTALUM
CTY353346Z
C604
.01uF 50WV KZ5U, MONO.
CK1103A87U
C605
CK1103AB7U
C606
CK1103AB7U
C607
.01uF 50WV K Z5 U, MONO.
CK1103AB7U
C608
CK1103AB7U
C609
CK1103AB7U
C610
CK1103A87U
C611
.01uF 50WV K Z5 U, MONl0.
CK1103A87U
C612
33PF 50WV J CH, MONO CHIP
CK1330AB4A
C613
CK1330AB4A
C614
.1uF 50WV Z Y5V, MONO.
CK2104AB7V
C615
.0027uF 50WV Z Y5V, MONO.
CK1272AB5R
C616
470PF 50WV K SL, MONO. CHIP
CK1471AB5L
C617
100PF 50WV K SL, MONO CHIP
CK1101AB5L
C618
CK1103AB7U
Integrated Circuits
Ref#
Description
MFR. Part No.
IC601
IC HD4074008F
ENH174008F
IC602
IC TC4069UBF
ENTA04069F
IC603
IC M5223FP
ENMI05223F
IC604
IC TC4069UBF
ENTA04069F
IC605
IC TA78
TZTA00078Z
IC606
IC TA78
TZTA00078Z
IC612
IC 7805
ENSS07805Z
Transistors
Ref#
Description
MFR. Part No.
TR601
TRANSISTOR 2SC945P
T2SC00945P
TR602
TRANSISTOR 2SC945P
T2SC00945P
TR603
TRANSISTOR 2SC945P
T2SC00945P
TR604
TRANSISTOR 2SC945P
T2SC00945P
TRANSISTOR 2SA1162GR
T2SA01162G
TR605
TRANSISTOR 2SC2712
T2SC02712G
TR606
TRANSISTOR 2SC2712
T2SC02712G
TR607
TRANSISTOR 2SC2712
T2SC02712G
Diodes
REF#
DESCRIPTION
PART#
D601
DIODE 1N5711
ED1N05711Z
D602
DIODE 1SS181
EDSS00181Z
D604
DIODE 1SS181
EDSS00181Z
D605
DIODE 1SS181
EDSS00181Z
Resonator
REF#
DESCRIPTION
PART#
X601
RESONATOR, 4MHZ, CERAMIC
EX14N46510
Switch
REF#
DESCRIPTION
PART#
S601
TACT SW
EWPS33042X
Buzzer
REF#
DESCRIPTION
PART#
BUZZER RKM35-4A
EX14N46511
Battery
REF#
DESCRIPTION
PART#
L1
BATTERY LITHIUM, 3V 170maH
EX08N41405
Connectors
REF#
DESCRIPTION
PART#
PCB CONNECTOR SOCKET 6P
EX07N41266
PCB CONNECTOR SOCKET 4P
EX07N41250
PCB CONNECTOR SOCKET 3P
EX07N41216
CN602
PCB CONNECTOR SOCKET 2P
EX07N41226
CN608
EX07N41226
CN609
EX07N41226
EX07N48244
EX07N48440
PCB CONNECTOR HOUSING 7P
EX07N48011
PCB CONNECTOR HOUSING 6P
EX07N48010
PCB CONNECTOR SOCKET 10P
EX07N48416
SHORT PIN 2P
EX07N48151
