Ranger RCI-2950
RX Alignment
RX Alignment Locations
SETTINGS CONNECTION
ADJUST
ADJUST FOR
AM/FM RF & IF SENSITIVITY:
Put mode selector on FM, RF gain fully clockwise, Clarifier at 12 o'clock, frequency at 28.0300 MHz.
Connect an FM signal generator to the antenna connector. Set modulation for ±3 kHz, output level at 0.5uV.
Connect a SINAD meter to the external speaker jack, volume control at about 10 o'clock.
Connect an oscilloscope with a X10 probe to the Cathode of D12. Set sweep selector for 1uS per division and vertical input selector for 10mV per division.
 L8
Adjust for best SINAD reading and least distorted waveform on scope. Do not try tuning this coil for maximum, as this will result in degraded receiver performance.
L9, L11
L12, L13
L14, L4
L3, L5
and L6
Adjust for maximum on scope. Reduce generator level if necessary, so as not to exceed vertical height on scope.
L5
L6
FM DETECTOR:
Mode FM.
Set FM RF Generator to 26.965 MHz 0.5uV deviated 3 KHz with 1KHz audio tone.
Reduce VOLUME as required.
L7
Adjust for maximum audio output.
SSB IF SENSITIVITY:
Put mode selector on LSB.
Signal generator to 28.0290 MHz, modulation off, output level at .5uV. Adjust Clarifier for best SINAD reading.
Connect oscilloscope same as above.
L15
L16
SSB S-METER:
Set mode to USB.
Increase RF Generator output to 26.966 MHz100uV (-67 dBm) unmodulated.
Set Squelch fully counterclockwise.
RF Generator to ANT Jack
VR2
Adjust for “S-9” meter reading.
AM/FM S-METER:
Set mode to AM.
RF Generator output to 100uV unmodulated.
Same as above
VR1
AM/FM SQUELCH RANGE:
Increase RF Generator output to 10mV.
Set Squelch Control fully clockwise.
Same as above
VR3
Adjust to the squelch just closes.
SSB SQUELCH RANGE:
Set mode to USB.
Same as above
VR4
NOISE BLANKER:
Set radio to 26.975MHz
Set mode to AM.
Set RF generator output to 26.965MHz at 1000uV unmodulated.
Set NOISE BLANKER switch to “ON”.
Connect DC Voltmeter to TP1 (Cathode of D2)
L1, L2
Adjust for maximum DC voltage.
Copyright © 1998,1999,2000, 2002 CBTricks.com
