Ranger
RCI-2950
TX Alignment
TX Alignment Locations
SETTINGS | CONNECTION |
ADJUST FOR |
Remove
TP1, TP2, TP3 Jumper PCB.
DRIVER
BIAS: Set mode to LSB Mic Gain to minimum |
Connect DC Ammeter between TP3 and TP2. |
VR11
In TX adjust for 50 to 60mA. |
FINAL
Connect DC Ammeter between TP3 and TP1. |
N/A
In TX check for 100-120mA. |
DO NOT ADJUST VC3 AS THIS IS PART OF 54 MHz TRAP Replace
Mode
LSB Frequency to 28.000MHz Adjust VR14 fully counterclockwise. Adjust VR12 fully counterclockwise. Set generator for 30mV RMS, 1KHz sinewave. |
Connect
an audio generator to (pin 2) and ground (pin 1) of Mic connector. Connect a wattmeter and 50ohm dummy load to the antenna connector. Set wattmeter for 30 Watt scale. |
Mic
Gain
Key the transmitter and slowly increase Mic Gain until you obtain about 10 Watts. |
L19,
L48
L47, L46, L43 |
Adjust for maximum reading on wattmeter. Reduce RF gain if necessary to maintain about 10 to 15 Watts on wattmeter. | ||
Increase
Mic gain to maximum (fully clockwise). |
Same as above. |
L34
Adjust for maximum output power |
SSB
CARRIER BALANCE: Set mode to USB MIKE GAIN to minimum. |
Same as above. |
VR7
Key TX; adjust for minimum carrier on scope or wattmeter. If necessary readjust for best balance of sideband suppression between LSB & USB |
SSB
HIGH PWR: With Mic gain still a maximum on LSB Set RF PWR control on radio to minimum. |
Same
as above. |
VR12
Key the transmitter and adjust for 25 Watts. |
SSB LOW
Same as above. |
VR16
Key the transmitter and adjust for 10 Watts. |
AM POWER
HIGH: Set RF PWR control on radio to maximum Put mode selector on AM. Mic Gain to minimum |
Connect a
30W scale. |
VR13
Key transmitter with no modulation applied and adjust for 10 Watts. |
AM POWER
LOW: Set RF PWR control on radio to minimum. Mic Gain to minimum |
Connect a wattmeter and 50ohm dummy load to the antenna connector. Set wattmeter for 30W scale. |
VR15
Key transmitter with no modulation applied and adjust for 2W. |
RF METER: Set RF PWR control on radio to maximum. Mic Gain to minimum. |
Connect a
30W scale. |
VR8
Adjust so panel meter agrees with Wattmeter. |
AMC: Mode to AM Set generator for 30mV RMS, 1KHz sinewave. With Mic gain at maximum |
Same as above. |
VR14
Adjust for 100% modulation. Use modulation meter or oscilloscope with RF sampler. |
FM DEVIATION: Put mode selector on FM |
Key transmitter and check for 4kHz deviation ± 0.5 kHz. Use deviation meter or service monitor. |
N/A
Simply check
for sufficient transmit audio. There is no deviation adjustment provided in this radio. |
