Ranger
RCI-2970
PLL Alignment
PLL
Alignment Locations
SETTINGS | CONNECTION |
ADJUST FOR |
Remove
TP1, TP2, TP3 Jumper PCB.
VCO & OSC: Frequency: 28.0000 MHz MIC Gain: Fully counter-clockwise RF Power. Fully clockwise RF Gain: Fully clockwise Clarifier: 12 o'clock Vol : Comfortable level Squelch: Fully counter-clockwise Mode selector - AM |
Disconnect shorting board from test points TP1, TP2 and TP3
Connect Freq. Counter to L61 |
VC1 |
Adjust for reading
of |
Connect Oscilloscope to L61 |
Adjust for Max. | |
Connect a Freq. Counter to L65 |
Adjust for 17.305MHz �10Hz. | |
Key
Transmitter and adjust for 17.305MHz �10Hz. |
Connect Voltmeter to IC7 Pin3 |
Adjust
for 1.2VDC �.1VDC. |
Connect Voltmeter to J13 |
Adjust
for 2.0VDC �.1VDC. |
Connect Oscilloscope to L65 |
Adjust for Max. | |
Connect
Freq. Counter to IC13 pin8 |
Very
carefully adjust for 11.350MHz �10Hz. |
Connect
Oscilloscope to IC17 pin13 |
L25 |
Very carefully adjust and for best waveform | |
AM TX OSC:
Same as above |
Connect a frequency counter to cathode of D45 |
Key
transmitter and adjust for 10.6950 MHz �10Hz. |
USB
TX OSC: Adjust VR7 fully clockwise. Put mode selector on USB. |
Leave frequency counter connected to D45 |
Key
transmitter and adjust for 10.6925 MHz �10Hz. |
LSB
TX OSC: Put mode selector in LSB. After adjustment return VR7 to approximate middle of rotation. |
L28
Key
transmitter and adjust for 10.6975 MHz �10Hz. |
