Realisitic
TRC-430
EXPLODED VIEW PART LIST
Ref. No. |
Description |
Mfr's Part No. |
1 |
PCB, Main |
401 -089A |
2 |
PCB, LED Display |
401 -398A |
3 |
Insulation Plate, PVC |
905-470 |
4 |
Connector, CH-239A, SW-1229 |
421-046-7 |
S |
Bushing-TR2078 |
441-004-5 |
6 |
Stopper-Cord |
750-765 |
7 |
Heatsink, ALP, IC MTG |
761-170 |
8 |
761-180 |
9 |
Heatsink, AL[P 61 x2OxT2 |
761-540 |
10 |
Holder-ANT, MTG |
732-560 |
11 |
Mica-TR2078 |
440-004-0 |
12 |
Mica-TR2314 |
440-005-1 |
13 |
(+) Machine Screw (B.H) M3x 10, Zn-Plate |
613-332 |
14 |
(+) Tapping Screw (B.H) 3x6-25, Zn-Plate |
623-265 |
15 |
(+) Tapping Screw (B.H) 3x6, Ni-Plate |
633-091 |
16 |
Shield Plate |
771-516 |
17 |
(+) Machine Screw (B.H) M2.6x6, Zn-Plate |
611-138 |
18 |
Nut, SS41, M3, Zn-Plate |
651-024 |
19 |
Spring Washer, M3, Zn-Plate |
662-30 5 |
20 |
Insulation Plate, Fiber |
902-050 |
21 |
5Pin Socket, Din Lock Type |
421-529-7 |
22 |
Heatsink, ALP l2x30xT0.8, TR MTG |
760-430 |
23 |
Shield Plate, 90x2SxT0.3 |
770-336 |
24 |
Shield Plate, 26x l7xT0.3 |
770-390 |
25 |
(+) Machine Screw (F.H) M2.6x5, Zn-Plate |
611-095 |
26 |
Power Cord, RED/WHT/BLK |
504-299 |
27 |
Upper Cover, BLK |
717-165 |
28 |
Felt Strip-Cover, BLK |
901-031 |
29 |
Felt Strip-Cover, B[K |
901-767 |
30 |
Insulation Plate, Fiber 147 xll4xTO.3 |
905-550 |
31 |
Bottom Cover, BLK |
7 17-160 |
32 |
Felt-SPK |
901-785 |
33 |
Cap-SPK, PE |
830-043 |
34 |
(+) Tapping Screw (B.H) M3x6, Zn-Plate, BLK |
623-274 |
54 |
Escutcheon, BLK |
801-116 |
55 |
Inlay |
794-375 |
56 |
Knob, CH, Up |
825-010 |
57 |
Knob, CH, Down |
825-005 |
58 |
Spring, ~0.3 |
881-320 |
59 |
Securing Screw, M6 x 9, BLK |
600-051 |
60 |
Bracket-STE, BLK |
720-4 1 1 |
61 |
Bracket-MIC |
720-09S |
62 |
(+) Tapping Screw (B.H) 3.5x6-25, Ni-Plate |
620-084 |
63 |
Washer-Rubber, BLK |
660-138 |
64 |
Washer M3.S, Lock "A" Type, Zn-Plate |
664-703 |
65 |
Wahser MS, Lock "B" Type, Zn-Plate |
664-S18 |
66 |
Screw (T.H) 5x12-15, Zn-Plate |
62S-007 |
67 |
Screw (B.H) 3 x 6, Tap-Tight, B[K |
633-082 |
68 |
Knob, Volume/Squelch, B[K |
82 5-1 55 |
69 |
Knob, Push, AN[ |
82S-000 |
70 |
Knob, Push, CH9 |
82S-001 |
71 |
Main Body |
701-935 |
72 |
Name Plate |
794-370 |
73 |
Blind Rivet |
670-02S |
74 |
Front Body |
701-930 |
75 |
Sponge-Rubber |
891-S90 |
VR101 |
Variable 10kB W/SW �20% |
4S0-403-0 |
VR102 |
Variable SOkA W/OFF-ON SW �20% |
450-622-1 |
SP-1 |
Speaker, 8 ohm 0.6W |
420-1 21-6 |
D303-D305 |
LED Lamp, GRN, 3V 20mA |
251-029-9 |
D306 |
LED Lamp, RED, 3V 20mA |
2S1-01 6-7 |
LED501 |
LED Display, GRN, 5V l60mA |
252-014-0 |
SW3-SW4 |
Push Switch, Self Lock |
432-040-6 |
SWS-SW6 |
Touch Switch, EVQ-QSR-OSK |
436-017-9 |
J1-J2 |
Jack Earphone HST 061 5-91-0100 |
420-707-6 |
