Realisitic TRC-430
Alignment Procedure
Receiver Section
A.Test Equipment Required
a.
RF Signal Generator
b.
SSVM
c.
Distortion Meter
d.
Power Supply
B.Alignment Procedure
STEP
SETTING
CONNECTION
ADJUST
ADJUST FOR
MIC: Receive
Volume: Fully clockwise
Squelch: Turn to counterclockwise
CH Selector: 19
ANL, CH9: OFF
SSG: 27.185MHz, 1kHz,
1MV30% Mod.
Connect RF signal generator to EXT-ANT jack. Connect SSVM and distortion meter across EXT speaker jack with 8 ohm dummy load
L101
L102
L103
L104
L105
Adjust for maximum indication on SSVM. Reduce output from RF SG until the audio output becomes about500mW (2V)
2
MIC: Receive
SSG: 27.185MHz1kHz
1mV80% Mod.
ANL, CH9: OFF
CH Selector: 19
Volume: 500mW (2V)
Connect RF Signal generator to EXT-ANT jack. Connect SSVM and distortion meter across EXT speaker jack with 8 ohm dummy load
L101
Adjust for minimum indication on distortion meter.
3
Squelch adjustment
MIC: Receive
1mV 30% Mod.
Squelch: Clockwise
CH Selector: 19
Volume: 500mW (2V)
ANL, CH9: OFF
RV103
Adjust RV103 until the audio output just appeared.
4
RF Signal meter adjustment
MIC: Receive
SSG: 27.185MHz, 1kHz100uV
30% Mod.
Squelch: Fully counter- clockwise
Volume: 500mW (2V)
ANL, CH9: OFF
Connect RF signal generator to EXT-ANT jack. Connect SSVM and distortion meter across the EXT speaker jack with8 ohm dummy load.
RV101
Adjust so that the 3rd light up.
