Realisitic TRC-430
Alignment Procedure
Phase Locked Loop and CPU Section
A. Test Equipment Required
a.
Frequency Counter
b.
DC Power Supply (13.8 Volt. 3 Amp.)
c.
DC Voltmeter
d.
Oscilloscope
B. Alignment Procedure
Step
Setting
Connection
Adjust
Adjust for
Frequency adjustment;
MIC: Receive
Volume: Optional
Squelch: Optional
CH Selector: Optional
Frequency counter to output pin 12 of IC102
CT201
10.240MHz � 100Hz
2
RX VCO voltage adjustment
MIC: Receive
Volume: Optional
Squelch: Turn Clockwise
CH Selector: 1
CH9: OFF
Connect DC voltmeter between R204 and R206
L301
1.5V
3
TX VCO voltage adjustment;
MIC: Transmit
Volume: Optional
Squelch: Optional
CH Selector: 1
CH9: OFF
L301
Indication on DC voltmeter must be 1.0-2.0 Volt. If DC voltmeter does not indicate 1.0-2.0 volt, readjust L301
4
CPU IC Voltage check;
MIC: Receive
Volume: Optional
Squelch: Optional
CH9: OFF
Connect DC voltmeter to pin 2 of IC101
Indication on DC voltmeter must be4-5.5 volt
5
CPU Frequency check;
MIC: Receive
Volume: Optional
Squelch: Optional
CH9: OFF
Connect oscilloscope to pin 16 of IC101
Check for 300-400kHz of triangle waveform
Transmitter Section
a. RF Powermeter (RF SSVM)
f. DC Power supply (13.8 Volt, 3 Amp.)
b. 50 ohm load (non-inductive)
g. Spectrum Analyzer
c. RF Attenuator
h. Frequency Counter
d. Oscilloscope
i. Coupler
e. Audio Generator
B. Alignment procedure
Step
Setting
Connection
Adjust
Adjust for
RF Driver stage;
MIC: Transmit
Volume: Optional
Squelch: Optional
CH Selector: 19
CH9:OFF
Connect RF powermeter to base of Q305
L302
L303
Adjust for maximum indication on the RF powermeter.
2
RF Power stage;
MIC: Trasmit
Squelch: Optional
Volume: Optional
CH selector: 19
CH9: OFF
Connect dummy load and RF powermeter to the EXT-ANT jack on the set
L304
L305
L306
L307
Adjust for maximum indication on the RF powermeter (4 watts). If indication is not in 4 watts range, go back to step 1 and readjust
3
Modulation adjustment;
MIC: Transmit
Volume: Optional
Squelch: Optional
CH Selector: 19
CH9: OFF
Connect audio generator(1kHz) to pin 4 of microphone connector Connect dummy load and oscilloscope through coupler to RF power meter. Connect RF power meter to EXT-ANT jack on the set adjust audio signal level to obtain 80%-90% modulation level.
RV104
Check for proper modulation pattern on the oscilloscope.
4
Second harmonic check;
MIC: Transmit
Volume: Optional
Squelch: Optional
CH Selector: 19
CH9: OFF
Connect RE powermeter with dummy load to spectrum analyzer through coupler/-4OdB attenuator to EXT-ANT jack on the set
At no modulation compare the level of fundamental frequency to the level of harmonic frequency. Suppression of the 2nd harmonic frequency level must be lower than-6OdB. Check for the other channels.
5
Frequency check;
MIC: Transmit
Volume: Optional
Squelch: Optional
Channel selector: 19
CH9: OFF
Connect dummy load and frequency counter through coupler to RF powermeter. Connect RF powermeter to EXT-ANT jack on the set
CT201
Make sure that the indication of the transmitter frequency is 27.1 85MHz � 300Hz on the frequency counter.
6
TX Power LED adjustment;
MIC: Transmit
Volume: Optional
Squelch: Optional
Channel Selector: 1
CH9: OFF
RV102
Adjust so that 3rd LED light up at 4 watts RF output power.
