Realisitic
TRC-435
TRANSISTOR VOLTAGE CHART
Unit [V]
REF. NO. |
RX |
TX |
PA |
B |
E |
C |
B |
E |
C |
B |
E |
C |
Q1 |
RF Att. |
0.15 �0.05 |
0 |
0.85 �0.1 |
0 |
0.85 �0.1 |
0 |
Q2 |
RF Att. |
0 |
0.15 �0.05 |
0 |
0.85 �0.1 |
0 |
0.85 �0.1 |
Q3 |
RF Gain |
Min. |
2.10 �0.1 |
1.60 �0.1 |
6.70 �0.1 |
0.15 �0.05 |
1.60 �0.1 |
0.40 �0.1 |
0.15 �0.05 |
1.60 �0.1 |
0.50 �0.1 |
Max. |
1.90 �0.1 |
1.15 �0.1 |
5.05 �0.1 |
0.15 �0.05 |
0.05 �0.05 |
0.50 �0.1 |
0.15 �0.05 |
0.05 �0.05 |
0.50 �0.1 |
Q4 |
1st Mixer |
(G)
0 |
(D) 7.10 �0.5 |
(S) 3.00 �0.5 |
(G)
0 |
(D) 7.20 �0.5 |
(S) 2.60 �0.5 |
(G) 0 |
(D) 7.30 �0.5 |
(S)
2.60 |
Q5 |
2nd Mixer |
0.95 �0.1 |
0.40 �0.1 |
7.20 �0.5 |
0.05 �0.05 |
0 |
0.40 �0.1 |
0.05 �0.05 |
0 |
0.50 �0.1 |
Q6 |
2nd IF Amp. |
0.70 �01 |
0 |
2.30 �0.2 |
0 |
0 |
0.40 �0.1 |
0 |
0 |
0.55 �0.1 |
Q7 |
2nd IF Amp |
2.30 �0.2 |
1.55 �0.1 |
13.3 �0.2 |
0.40 �0.1 |
0 |
13.4 �0.2 |
0.55 �0.1 |
0 |
13.7 �0.2 |
Q8 |
AF Pre Amp |
1.80 �0.2 |
1.15 �0.2 |
3.20 �0.2 |
1.80 �0.2 |
1.15 �0.2 |
3.20 �0.2 |
1.80 �0.2 |
1.15 �0.2 |
3.20 �0.2 |
Q9 |
AF Drive Amp |
6.15 �0.2 |
5.85 �0.2 |
7.10 �0.2 |
6.15 �0.2 |
5.85 �0.2 |
7.10 �0.2 |
6.15 �0.2 |
5.85 �0.2 |
7.10 �0.2 |
Q10 |
AGC Det. |
0 |
0 |
7.15 �0.3 |
0 |
0 |
0.45 �0.1 |
0 |
0 |
0.55 �0.1 |
Q11 |
PA Switch |
0 �0.1 |
0.40 �0.1 |
13.7 �0.2 |
0 �0.1 |
0 |
13.4 �0.3 |
1.20 �0.1 |
0.65 �0.1 |
13.7 �0.2 |
Q12 |
SQ |
Min. |
0.45 +0.1 |
0.05 �0.05 |
0.70 �0.1 |
0.45 �0.1 |
0.05 �0.05 |
0.70 �0.1 |
0.45 �0.1 |
0.05 �0.05 |
0.70 �0.1 |
Max. |
0.70 �0.1 |
0.10 �0.1 |
0.10 �0.1 |
0.70 �0.1 |
0.10 �0.1 |
0.10 �0.1 |
0.70 �0.1 |
0.10 �0.1 |
0.10 �0.1 |
Q13 |
SQ |
Min. |
0.70 �0.1 |
0.05 �0.05 |
0.10 �0.1 |
0.70 �0.1 |
0.05 �0.05 |
0.10 �0.1 |
0.70 �0.1 |
0.05 �0.05 |
0.10 �0.1 |
Max. |
0.10 �0.1 |
0.05 �0.05 |
1.10 �0.1 |
0.10 �0.1 |
0.05 �0.05 |
1.25 �0.1 |
0.10 �0.1 |
0.05 �0.05 |
1.25 �0.1 |
Q14 |
PA Amp |
0 |
0 |
0 |
0 |
0 |
0 |
1.35 �0.3 |
0.70 �0.1 |
1.90 �0.3 |
Q15 |
TX Driver |
0 |
0 |
13.4 �0.3 |
0 |
0 |
12.5 �0.5 |
0 |
0 |
13.4 �0.3 |
Q16 |
TX Pre Driver |
0 |
0.10 �0.1 |
13.7 �0.2 |
2.60 �0.4 |
2.25 �0.4 |
9.00 �0.5 |
2.60 �0.4 |
2.25 �0.4 |
9.3 �0.5 |
Q17 |
TX RF Amp. |
0 |
0.10 �0.1 |
0 |
3.00 �0.4 |
2.40 �0.4 |
6.10 �0.4 |
0.45 �0.1 |
0.85 �0.1 |
7.80 �0.5 |
Q18 |
PA Switch |
8.00 �0.3 |
8.00 �0.3 |
0 |
8.00 �0.3 |
8.00 �0.3 |
0 |
7.30 �0.3 |
8.00 �0.3 |
8.00 �0.3 |
Q19 |
AWI Amp. |
0 |
0 |
8.00 �0.3 |
0.25 �0.1 |
0 |
8.00 �0.3 |
0 |
0 |
8.00 �0.3 |
Q20 |
AWI Amp. |
8.00 �0.3 |
5.80 �0.5 |
0 |
8.00 �0.3 |
5.50 �0.4 |
0 |
8.00 �0.3 |
5.80 �0.5 |
0 |
Q21 |
TX Switch |
0 |
0 |
5.90 �0.3 |
0 |
0 |
5.90 �0.3 |
0.70 �0.1 |
0 |
0.15 �0.1 |
Q22 |
TX/RX Switch |
7.90 �0.3 |
8.00 �0.3 |
0 |
7.25 �0.3 |
8.00 �0.3 |
7.65 �0.3 |
7.25 �0.3 |
8.00 �0.3 |
7.80 �0.3 |
Q23 |
TX/RX Switch |
7.95 �0.3 |
7.25 �0.3 |
8.00 �0.3 |
0.05 �0.05 |
0.40 �0.1 |
8.00 �0.3 |
0.05 �0.05 |
0.55 �0.1 |
8.00 �0.3 |
Q24 |
Mic. Amp. |
1.70 �0.2 |
2.90 �0.3 |
8.00 �0.3 |
1.60 �0.2 |
1.00 �0.2 |
5.35 �0.2 |
1.70 �0.2 |
2.25 �0.3 |
8.00 �0.3 |
Q25 |
AMC Amp. |
0.20 �0.1 |
0 |
0 |
0.20 �0.1 |
0 |
0 |
0.20 �0.1 |
0 |
0 |
Q26 |
1st Local Amp. |
0.60 �0.1 |
0 |
6.10 �0.3 |
0.60 �0.1 |
0 |
6.10 �0.3 |
0.60 �0.1 |
0 |
6.10 �0.3 |
Q27 |
Mod. Ind. Amp. |
0 |
0 |
5.80 �0.3 |
0 |
0 |
5.60 �0.3 |
0 |
0 |
5.80 �0.3 |
Q28 |
SQ |
Min. |
0.15 �0.05 |
0 |
0 |
0.80 +0.1 |
0 |
0 |
0.80 �0.1 |
0 |
0 |
Max. |
0.60 �0.1 |
0 |
0 |
0.80 +01 |
0 |
0 |
0.80 �0.1 |
0 |
0 |
Q501 |
TX Final |
0 |
0 |
13.4 �0.3 |
0 |
0 |
12.0 �0.5 |
0 |
0 |
13.4 �0.3 |
Q701 |
VCO Buffer |
4.60 +0.3 |
4.0 �0.3 |
6.40 �0.3 |
4.60 �0.3 |
4.0 �0.3 |
6.40 �0.3 |
4.60 �0.3 |
4.0 �0.3 |
6.40 �0.3 |
Q702 |
VCO |
3.70 �0.3 |
3.10 �0.3 |
6.40 �0.3 |
3.70 �0.3 |
3.10 �0.3 |
6.40 �0.3 |
3.70 �0.3 |
3.10 �0.3 |
6.40 �0.3 |
Q703 |
TX Switch |
0 |
0 |
7.40 �0.3 |
0.70 �0.2 |
0 |
0 |
0.70 �0.2 |
0 |
0 |
NOTE:
Measurement performed at No Signal, No Modulation. Power Supply Voltage: DC
13.8 V
Measurement Channel:
18 CH
B: Base
F: Emitter
C: Collector
(G):
Gate
(D): Drain
(S): Source
