Realisitic
TRC-435
MAIN PCB ASSEMBLY PARTS LIST
ASSEMBLY, PCB, MAIN�� AT336ZPB EA
The following
codes indicate variations of capacitors against temperatures;
YA= + 5%,YB= � 10%,YD= +20-30%,YE= +20-50%(-25-~-+85�C),YF(F)= +30-80%, ZF= +30 -80% (-10---+700C),CH=0
� 60ppm/0C,RH=220ppm/0C � 60ppm/�C,TH= -470ppm/�C
� 60ppm/0C,SL= +350ppm/�C--1000ppm/�C,UJ= -7SOppm/�C � 120ppm/0C
CAPACITORS
REF. NO. |
DESCRIPTION |
MFR'S PART NO. |
C001 |
Ceramic l5pF 50V �10% RH |
BCCR8115O5Z |
C002 |
Ceramic 0.0022uF 50V �20% YD(D) |
BCKD812226Z |
C003 |
BCKD812226Z |
C004 |
Ceramic 0.01uF 50V +80, -20% YF(F) |
BCKG811030Z |
C005 |
BCKD812226Z |
C006 |
BCKG811030Z |
C007 |
Ceramic 0.0047uF 50V +80, -20% YF(F) |
BCKG814720Z |
C008 |
Ceramic 0.047uF 25V +80, -20%ZF |
BCKC514730Z |
C009 |
Ceramic 100pF 50V �10% CH |
BCCC811015Z |
C010 |
-Not Used- |
C011 |
Electrolytic 22uF 16V �20% |
BCAX312206Z |
C012 |
BCKCS14730Z |
C013 |
Semi-Conductor (SR) 0.022uF 25V �10% |
BCGC512235Z |
C014 |
Electrolytic 47uF 25V �20% |
BCAK514706Z |
C015 |
Ceramic O.047uF 25V +80, -20%ZF |
BCKCS14730Z |
C016 |
Ceramic 0.047uF 25V +80, -20% ZF |
BCKC514730Z |
C017 |
BCAX312206Z |
C018 |
BCKCS14730Z |
C019 |
Ceramic 150pF 50V �10% SL |
BCCG811S15Z |
C020 |
-Not Used- |
C021 |
BCCC811015Z |
C022 |
BCGC512235Z |
C023 |
Electrolytic 2.2uF 50 V �20% |
BCAX812296Z |
C024 |
Ceramic 0.001uF 50V �10% YB(B) |
BCKB811025Z |
C025 |
Electrolytic 1uF 50V �20% |
BCAX811096Z |
C026 |
Semi-Conductor (SR) 0.01 uF 25V �10% |
BCGCS11035Z |
C027 |
Semi-Conductor (SR) 0.001uF 25V �10% |
BCGC511025Z |
C028 |
Ceramic 0.0022uF 50V �10% YB(B) |
BCKB812225Z |
C029 |
BCAX312206Z |
C030 |
-Not Used- |
C031 |
Semi-Conductor (SR) 0.0033uF 25V �10% |
BCGC513325Z |
C032 |
Semi-Conductor (SR) 0.047uF 25V �10% |
BCGC514735Z |
C033 |
Semi-Conductor (SR) 0.033uF 25V �10% |
BCGC513335Z |
C034 |
-Not Used- |
C035 |
Electrolytic 10uF 35V �20% |
BCAX661006Z |
C036 |
BCKG814720Z |
C037 |
BCAX312206Z |
C038 |
-Not Used- |
C039 |
Electrolytic 100uF 1OV �20% |
BCAX111016Z |
C040 |
Semi-Conductor (SR) 0.047uF 25V � 10% |
BCGCS14735Z |
C041 |
Electrolytic 3.3uF 50V �20% |
BCAX813396Z |
C042 |
Electrolytic 22uF 10V �20% |
BCAH112206Z |
C043 |
Electrolytic 2.2uF 50V �20% |
BCAX812296Z |
C044 |
BCAX312206Z |
C045 |
Semi-Conductor (SR) 0.01uF 25V � 10% |
BCGCS11035Z |
C046 |
Electrolytic 47uF 1OV �20% |
BCAX114706Z |
C047 |
Electrolytic 100uF 10V �20% |
BCAX111016Z |
C048 |
Semi-Conductor (SR) 0.015uF 25V �10% |
BCGCS11535Z |
C049 |
Ceramic 68pF 50V �5% RH |
BCCR816804Z |
C050 |
-Not Used- |
C051 |
Ceramic 150pF 50V �10 SL |
BCCG811S15Z |
C052 |
Ceramic 22pF 50V �10% SL |
BCCG812205Z |
C053 |
Ceramic 220pF 50V �10% SL |
BCCG812215Z |
C054 |
Ceramic 47pF 50V �5% CH |
BCCC8l4704Z |
C055 |
BCCG812215Z |
C056 |
Ceramic 330pF 50V �10% UJ |
BCCU813315Z |
C057 |
Ceramic 120pF 50V �10% SL |
BCCG811215Z |
C058 |
Ceramic 220pF 50V �10% UJ |
BCCU812215Z |
C059 |
-Not Used- |
C060 |
Ceramic 0.01uF 50V �20% YD(D) |
BCKD811036Z |
C061 |
Ceramic 0.0047uF 50V �20% YD(D) |
BCKD814726Z |
C062 |
Ceramic 33pF 50V �10% UJ |
BCCU813305Z |
C063 |
Ceramic 0.001uF 50V �20% YD(D) |
BCKD811026Z |
C064 |
Semi-Conductor (SR) 0.01uF 25V �10% |
BCGC511035Z |
C065 |
Ceramic 470pF 50V �10% UJ |
BCCU814715Z |
C066 |
BCGC511035Z |
C067 |
BCKD811026Z |
C068 |
BCKC514730Z |
C069 |
BCKG814720Z |
C070 |
-Not Used- |
C071 |
BCKG811030Z |
C072 |
BCAX661006Z |
C073 |
BCKD811026Z |
C074 |
BCGC511035Z |
C075 |
Ceramic 0.0047uF 50V +80, -20%YF(F) |
BCKG814720Z |
C076 |
BCKD811026Z |
C077 |
BCKG8ll030Z |
C078 |
BCAX812296Z |
C079 |
BCKD811036Z |
C080 |
-Not Used- |
C081 |
Semi-Conductor (SR) 0.0027uF 25V �10% |
BCGC512725Z |
C082 |
BCGCS11535Z |
C083 |
BCGC511025Z |
C084 |
Electrolytic 2.2uF 25V �20% |
BCAK512296Z |
C085 |
Electrolytic 33uF 16V �20% |
BCAX313306Z |
C086 |
Ceramic 0.0022uF 50V � 10% YB(B) |
BCKB812225Z |
C087 |
Semi-Conductor (SR) 0.1uF 25V � 10% |
BCGC511045Z |
C088 |
Electrolytic 470uF 10V �20% |
BCAK1 14716Z |
C089 |
BCKD811036Z |
C090 |
-Not Used- |
C091 |
Electrolytic 1000uF 25V �20% |
BCAX511026Z |
C092 |
BCKD811026Z |
C093 |
BCKD811026Z |
C094 |
BCKD811026Z |
C095 |
BCAX812296Z |
C096 |
BCAX812296Z |
C097 |
BCKD811026Z |
C098 |
Ceramic 33pF 50V �5% CH |
BCCC813304Z |
C099 |
Ceramic 330pF 50V �5% SL |
BCCG813314Z |
C100 |
-Not Used- |
C101 |
Ceramic 270pF 50V �5% CH |
BCCC812714Z |
C102 |
Electrolytic 220uF 10V �20% |
BCAX112216Z |
C103 |
Ceramic 0.0047uF 50V +80, -20%ZF |
BCKC51473OZ |
C104 |
Ceramic 1.01uF 50V +80, -20%YF(F) |
BCKG8l1O3OZ |
C105 |
BCKD811O26Z |
C106 |
BCAX112216Z |
C107 |
-Not Used- |
C108 |
BCKD811026Z |
C109 |
Electrolytic 0.47uF 50V �20% |
BCAX814786Z |
C110 |
BCKG814720Z |
C111 |
BCAX312206Z |
C112 |
BCGC514735Z |
C113 |
BCCG8l1S15Z |
C114 |
Semi-Conductor (SR) 0.0047uF 25V �10% |
BCGC514725Z |
C115 |
BCGC514735Z |
C116 |
Ceramic 0.00luF 50V �20% YD(D) |
BCKD811026Z |
C117 |
BCKG814720Z |
C118 |
BCAX312206Z |
C119 |
BCAKS12296Z |
C120 |
-Not Used- |
C121 |
BCAX111016Z |
C122 |
Tantalum 0.47uF 35V �20% |
BC5E664786Z |
C123 |
BCAX811096Z |
C124 |
BCAX661006Z |
C125 |
BCAX661006Z |
C126 |
BCAX66l006Z |
C127 |
-Not Used- |
C128 |
-Not Used- |
C129 |
BCKG8l472OZ |
C130 |
-Not Used- |
C131 |
BCGC511035Z |
C132 |
BCGC511035Z |
C133 |
BCGC511035Z |
C134 |
BCGC514735Z |
C135 |
BCGC514735Z |
C136 |
BCKC514730Z |
C137 |
BCKC5l4730Z |
C138 |
BCKC514730Z |
C139 |
BCKC514730Z |
