Realisitic
TRC-435
MAIN PCB ASSEMBLY PARTS LIST
RESISTORS
NOTE:� All resistors are Carbon Formed Vertical Chip 1/6 watt, � 5% unless otherwise specified.
REF. NO. |
DESCRIPTION |
MFR'S PART NO. |
R001 |
330 ohm |
BRUB613314Z |
R002 |
1k ohm |
BRUB611024Z |
R003 |
470 ohm |
BRUB614714Z |
R004 |
Carbon AXTS26 2.2k ohm 1/6W �5% |
BRPA612224Z |
R005 |
220 ohm |
BRUB612214Z |
R006 |
5.6k ohm |
BRUB615624Z |
R007 |
Carbon Axial Lead 1.8k ohm 1/8W �5% |
BRFT181824Z |
R008 |
470 ohm |
BRUB614714Z |
R009 |
390 ohm |
BRUB613914Z |
R010 |
1k ohm |
BRUB611024Z |
R0ll |
10k ohm |
BRUB611034Z |
R012 |
1.5k ohm |
BRUB611524Z |
R013 |
Carbon AXTS26 1k ohm 1/6W�S% |
BRPA611024Z |
R014 |
2.2k ohm |
BRUB612224Z |
R015 |
330 ohm |
BRUB613314Z |
R016 |
220k ohm |
BRUB612244Z |
R017 |
1k ohm |
BRUB611024Z |
R018 |
2.2k ohm |
BRUB612224Z |
R019 |
l5k ohm |
BRUB611534Z |
R020 |
-Not Used- |
R021 |
2.2k ohm |
BRUB612224Z |
R022 |
Carbon Axial Lead 330 ohm 1/8W �5% |
BRPBl83314Z |
R023 |
100 ohm |
BRUB611014Z |
R024 |
CarbonAXTS26 100 ohm 1/6W �5% |
BRPA611014Z |
R025 |
l0k ohm |
BRUB611034Z |
R026 |
56k ohm |
BRUB615634Z |
R027 |
33k ohm |
BRUB613334Z |
R028 |
22k ohm |
BRUB612234Z |
R029 |
22k ohm |
BRUB612234Z |
R030 |
-Not Used- |
R031 |
33k ohm |
BRUB613334Z |
R032 |
39k ohm |
BRUB613934Z |
R033 |
390k ohm |
BRUB613944Z |
R034 |
470 ohm |
BRUB614714Z |
R035 |
l00k ohm |
BRUB611044Z |
R036 |
39k ohm |
BRUB613934Z |
R037 |
270k ohm |
BRUB612744Z |
R038 |
820 ohm |
BRUB618214Z |
R039 |
2.7k ohm |
BRUB612724Z |
R040 |
-Not Used- |
R041 |
33k ohm |
BRUB613334Z |
R042 |
560k ohm |
BRUB615644Z |
R043 |
22k ohm |
BRUB612234Z |
R044 |
22k ohm |
BRUB612234Z |
R045 |
Carbon AXTS26 470 ohm 1/6W �5% |
BRPA614714Z |
R046 |
330 ohm |
BRUB613314Z |
R047 |
56 ohm |
BRUB615604Z |
R048 |
680 ohm |
BRUB616814Z |
R049 |
Carbon Axial Lead 27k ohm 1/6W � 5% |
BRPB612734Z |
R050 |
-Not Used- |
R051 |
3.3k ohm |
BRUB613324Z |
R052 |
27k ohm |
BRUB612734Z |
R053 |
3.3k ohm |
BRUB613324Z |
R054 |
68k ohm |
BRUB616834Z |
R055 |
100k ohm |
BRUB611044Z |
R056 |
150k ohm |
BRUB611544Z |
R057 |
470 ohm |
BRUB614714Z |
R058 |
330 ohm |
BRUB613314Z |
R059 |
82k ohm |
BRUB618234Z |
R060 |
-Not Used- |
R061 |
470 ohm |
BRUB614714Z |
R062 |
2.7k ohm |
BRUB612724Z |
R063 |
l80k ohm |
BRUB611844Z |
R064 |
33k ohm |
BRUB613334Z |
R065 |
2.2k ohm |
BRUB612224Z |
R066 |
Carbon AX TS 26 390 ohm 1/6W �5% |
BRPA613914Z |
R067 |
180 ohm |
BRUB611814Z |
R068 |
Carbon Axial Lead 15 ohm 1/8W �5% |
BRPB181504Z |
R069 |
2.7 ohm |
BRUB612794Z |
R070 |
-Not Used- |
R071 |
180 ohm |
BRUB611814Z |
R072 |
Carbon AX TS26 3.9 ohm 1/6W � 5% |
BRPA613994Z |
R073 |
27 ohm |
BRUB612704Z |
R074 |
Carbon AX TS 26 82 ohm 1/6W �5% |
BRPA618204Z |
R075 |
CarbonAXTS26 1k ohm 1/6W �5% |
BRPA611024Z |
R076 |
CarbonAXTS26 8.2k ohm 1/6W �5% |
BRPA618224Z |
R077 |
l5k ohm |
BRUB611534Z |
R078 |
CarbonAXTS26 180 ohm 1/6W �5% |
BRPA611814Z |
R079 |
180 ohm |
BRUB611814Z |
R080 |
-Not Used- |
R081 |
5.6k ohm |
BRUB615624Z |
R082 |
10k ohm |
BRUB611034Z |
R083 |
15k ohm |
BRUB611534Z |
R084 |
Carbon AX TS 26 150 ohm 1/8W �5% |
BRPA181514Z |
R085 |
10k ohm |
BRUB611034Z |
R086 |
1k ohm |
BRUB611024Z |
R087 |
100k ohm |
BRUB611044Z |
R088 |
1.8k ohm |
BRUB611824Z |
R089 |
2.2k ohm |
BRUB612224Z |
R090 |
-Not Used- |
R091 |
Carbon AXTS26 56k ohm 1/6W �5% |
BRPA615634Z |
R092 |
820 ohm |
BRUB618214Z |
R093 |
1.5k ohm |
BRUB611524Z |
R094 |
33k ohm |
BRUB613334Z |
R095 |
Carbon AXTS26 33k ohm 1/6W �5% |
BRPA613334Z |
R096 |
Carbon AXTS26 10k ohm 1/8W �5% |
BRPA181034Z |
R097 |
56k ohm |
BRUB615634Z |
R098 |
220 ohm |
BRUB612214Z |
R099 |
Carbon AXTS26 8.2k ohm 1/6W �5% |
BRPA618224Z |
R100 |
1k ohm |
BRUB611024Z |
R100 |
Carbon Formed Vertical 1k ohm 1/8W �5%(ForCA) |
BRUB181024Z |
R101 |
1 ohm |
BRUB611094Z |
R102 |
Carbon AXTS26 l2k ohm 1/8W�5% |
BRPA181234Z |
R103 |
Carbon Axial Lead 27k ohm 1/8W �5% |
BRFT182734Z |
R103 |
Carbon AX TS 26 27k ohm 1/8W �5% (For CA) |
BRPA182734Z |
R104 |
l0k ohm |
BRUB611034Z |
R105 |
2.2k ohm |
BRUB612224Z |
R106 |
Carbon Axial Lead 150 ohm 1/8W�%5 |
BRFT181514Z |
R107 |
2.2k ohm |
BRUB612224Z |
R108 |
2.2k ohm |
BRUB612224Z |
R109 |
2.2k ohm |
BRUB612224Z |
R110 |
1k ohm |
BRUB611024Z |
R111 |
2.2k ohm |
BRUB612224Z |
R112 |
2.2k ohm |
BRUB612224Z |
R113 |
Carbon Axial Lead 150 ohm 1/8W�5% |
BRFT181514Z |
R114 |
390k ohm |
BRUB613944Z |
R115 |
Carbon AXTS26 560 ohm 1/6W �5% |
BRPA615614Z |
R116 |
Carbon AXTS26 33 ohm 1/6W�5% |
BRPA613304Z |
R117 |
l0k ohm |
BRUB611034Z |
R118 |
Carbon AXTS26 6.8k ohm 1/6W �5% |
BRPA616824Z |
R119 |
47k ohm |
BRUB614734Z |
R120 |
-Not Used- |
R121 |
1.5k ohm |
BRUB611524Z |
R122 |
3.3k ohm |
BRUB613324Z |
R123 |
3.3k ohm |
BRUB613324Z |
R124 |
2.2k ohm |
BRUB612224Z |
R125 |
3.9k ohm |
BRUB613924Z |
R126 |
82k ohm |
BRUB618234Z |
R127 |
22k ohm |
BRUB612234Z |
R128 |
47k ohm |
BRUB614734Z |
R129 |
2.2k ohm |
BRUB612224Z |
R130 |
-Not Used- |
R131 |
18k ohm |
BRUB611834Z |
R132 |
470k ohm |
BRUB614744Z |
R133 |
220 ohm |
BRUB612214Z |
R134 |
22k ohm |
BRUB612234Z |
R135 |
3.3k ohm |
BRUB613324Z |
R136 |
3.3k ohm |
BRUB613324Z |
R137 |
3.3k ohm |
BRUB613324Z |
R138 |
2.2k ohm |
BRUB612224Z |
R139 |
2.2k ohm |
BRUB612224Z |
R140 |
-Not Used- |
R141 |
2.2k ohm |
BRUB612224Z |
R142 |
Carbon AX TS 26 680 ohm 1/6W �5% |
BRPA616814Z |
R143 |
330 ohm |
BRUB613314Z |
R144 |
680 ohm |
BRUB616814Z |
R145 |
Carbon AXTS26 680 ohm 1/6W �5% |
BRPA616814Z |
R146 |
Carbon Axial Lead 680 ohm 1/8W �5% |
BRFT186814Z |
R147 |
BRFT1l86814Z |
R148 |
680 ohm |
BRUB616814Z |
R149 |
BRFT186814Z |
R150 |
-Not Used- |
R151 |
Carbon Axial Lead 1k ohm 1/8W �5% |
BRFT181024Z |
R152 |
Carbon Axial Lead 2.2k ohm 1/8W �5% |
BRFT182224Z |
R153 |
8.2 ohm |
BRUB618294Z |
R154 |
Carbon Axial Lead 100 ohm 1/8W �5% |
BRFT181014Z |
R155 |
Carbon AX TS 26 1k ohm 1/6W�5% |
BRPA611024Z |
R156 |
6.8k ohm |
BRUB616824Z |
VARIABLE RESISTORS
REF. NO. |
DESCRIPTION |
MFR'S PART NO. |
VR001 |
Resistor Semi-Fixed RT-528 47KB |
BRTY0528473 |
VR002 |
BRTY0528473 |
VR003 |
Resistor Semi-Fixed RT-182 TT24R 500KB |
BRTY0182504 |
VR004 |
Resistor Semi-Fixed RT-182 TT24R 3KB |
BRTY0182302 |
