Realisitic TRC-435
MAIN PCB ASSEMBLY PARTS LIST
MISCELLANEOUS
REF. NO.
DESCRIPTION
MFR'S PART NO.
T001
Transformer Output TF-215
BTFY02l5001
T002
Transformer TF-374
BTFYO374001
X001
Crystal QX-308 10.2419 MHz
BQXY0308001
YI101
Heat Sink YD-058 TESS
BYDY0058001
JACKS
REF. NO.
DESCRIPTION
MFR'S PART NO.
J001
EXP.SP 3.60 JK-089 H5J0615
BJKY0089001
J002
PA.SP 3.60 JK-089 H5J0615
BJKY0089001
MISCELLANEOUS
REF. NO.
DESCRIPTION
MFR'S PART NO.
B601
PCB, CM Coupler PA-210AA
BPAY0210AAZ
C501
Capacitor Ceramic 68pF 50V �10% SL
BCCG816805Z
J501
Jack ANT. JK-426 M-RM-L
BJKY0426001
J502
Jack DC JK-052 Black
BJKY0052002
Q501
Transistor Silicon NPN DB-331 25C2166-C
BDBC2166103
S501
Switch Rotary SR-413
BSRY0413001
FC501
Flat Cable WF-058 3-80- 3
BWFY0580809
IC501
Integrated Circuit Linear L7808CV
BDEY0157001
SP501
Speaker 3W l6 ohm 77mm SP-188
BSPY0188001
VR501
Resistor Variable RV-708 50KA
BRVY0708001
VR502
Resistor Variable RV-725 50KA
BRVY0725001
VR503
Resistor Variable RV-652 VBl2L PVB2OF B1K
BRVY0652001
VR504
Resistor Variable RV-650 VB12L PVB2OF B50K
BRVY0650001
YI501
Insulation Sheet YD-046
BYDY0046001
YI502
Insulation Sheet YY-027
BYYY0027001
YI503
Bushing Transistor YD-019 B309D
BYDY0019004
YI504
Bushing Transistor YD-019 B312D-l1-A
BYDY0019003
YI505
BYDY0058001
W001
Wire UL 1007 #24 10-40-3 WHT
CUAJ004041Z
W002
Wire UL 1007 #24 10-50-3 RED
CUAB005041Z
W003
Wire UL 1007 #24 10-50-3 BLK
CUAK005041Z
W004
Wire UL 1007 #24 10-70-3 RED
CUAB007041Z
W005
Wire UL 1007 #24 10-70-3 ORG
CUAC007041Z
W006
Wire UL 1007 #24 10-150-3 GRY
CUAH015041Z
W007
CUAH01S041Z
W008
Wire UL 1007 #24 10-50-5 BLK
CUAK005042Z
W009
Wire UL 1007 #24 10-50-5 BLU
CUAF006042Z
W010
Wire UL 1007 #24 10-60-5 YEL
CUAD006042Z
W011
Wire UL 1007 #24 10-90-5 VIO
CUAG009042Z
W012
Wire UL 1007 #24 10-110-10 BLK
CUAK011044Z
W013
Wire UL 1007 #24 10-120-10 BLK
CUAK012044Z
W014
Wire UL 1007 #24 10-100-10 BLK
CUAK010044Z
MC951
Microphone Dynamic MK-215 BMKY0215001
WA951
Cord DC WZ-517 1515 W/P
BWZY0517001
Copyright © 1998,1999,2000 CBTricks.com
