Realisitic TRC-435
FRONT PCB ASSEMBLY
ASSEMBLY, PCB, FRONT��� AT336ZPBEB
CAPACITORS
The following codes indicate variations of capacitors against temperatures;
YA- � 5%,YB= � l0%,YD= +20-30%,YE= +20-50%(-25--+85°C),ZF= +30-80%(-10---+70°C) CH=0 + 0ppm/°C,RH=220ppm/°C � 60ppm/°C,TH= -47oppm/°C � 60ppm/°C,SL= +350ppm/°C--lOOOppm/°C,UJ= -750ppm/°C � l20ppm/°C
REF. NO.
DESCRIPTION
MFR'S PART NO.
C551
Semi-Conductor (SR) 0.01uF 25V � 10%
BCGC511035Z
C552
Semi-Conductor (SR) 0.0082uF 25V � 10%
BCGCS18225Z
C553
Electrolytic 10uF 16V �20%
BCER311006Z
DIODES
REF. NO.
DESCRIPTION
MFR'S PART NO.
D551
LED Display LDR204AL
BDAY0202001
D552
LED GL8PR2lT (B)
BDAY0489002
D553
LED GL8PR21T (B)
BDAY0489002
D554
LED GL8PR2lT (B)
BDAY0489002
D555
LED GL8PR21T (B)
BDAY0489002
D556
LED GL8PR21T (B)
BDAY0489002
D557
LED GL8PR2lT (B)
BDAY0489002
D558
LED GL8PR21T (B)
BDAY0489002
D559
LED GL8PR21T (B)
BDAY0489002
D560
Silicon 1N4148
BDAY0246001
RESISTORS
NOTE: All resistors are Carbon AX TS 26 Type, 1/6 watt +5% unless otherwise specified.
REF. NO.
DESCRIPTION
MFR'S PART NO.
R551
680 ohm
BRPA616814Z
R552
680 ohm
BRPA616814Z
R553
680 ohm
BRPA616814Z
R554
680 ohm
BRPA616814Z
RSSS
680 ohm
BRPA616814Z
R556
10k ohm
BRPA611034Z
R557
15k ohm
BRPA611534Z
R558
1.8k ohm
BRPA611824Z
R559
820 ohm
BRPA618214Z
SWITCHES
REF. NO.
DESCRIPTION
MFR'S PART NO.
S551
Slide 3 points SW-672
B5WY0672001
S552
Slide SW-430 55FU22-145K
BSWY0430001
S553
Slide SW-430 SSFU22-145K
BSWY0430001
INTEGRATED CIRCUIT
REF. NO.
DESCRIPTION
MFR'S PART NO.
IC551
Bipolar LB1423N
BDEY0430001
Copyright © 1998,1999,2000 CBTricks.com
