Realisitic TRC-435
VCO PCB ASSEMBLY
ASSEMBLY, PCB, VCO����� AT336ZPBEC
NOTE: All capacitors are Ceramic MIL (3216) Type unless otherwise specified.
The following codes indicate variations of capacitors against temperatures;
VA- � 5% YB= + l0%,YD= +20-30%,YE= +20-50%(-25---+85°C),B= + 10-30%,ZF= +30-80%(-10--+70°C) CH=0 + 60ppm/°C,RH=220ppm/°C � 60ppm/°C,CG=0 � 60ppm/°C, TH= -470ppm/°C � 60ppm/°C,SL= +350ppm/°C--1000ppm/°C,UJ= -750ppm/°C � 120ppm/°C
CAPACITORS
REF. NO.
DESCRIPTION
MFR'S PART NO.
C701
39pF 50V �5% SL
BCXQ813904Z
C702
0.01uF 50V �10% B
BCXS811035Z
C703
0.01uF 50V �10% B
BCXS811035Z
C704
0.01uF 50V �10% B
BCXS811035Z
C705
39pF 50V �5% SL
BCXQ813904Z
C706
15pF 50V �5% CG
BCXD811504Z
C707
47pF 50V �5% UJ
BCXP814704Z
C708
100pF 50V �10% UJ
BCXP811015Z
C709
330pF 50V �10% UJ
BCXP813315Z
C710
-Not Used-
C711
39pF 50V �5% CG
BCXD813904Z
C712
68pF 50V �5% SL
BCXQ816804Z
C713
0.01uF 50V �10% B
BCXS811035Z
C714
0.01uF 50V �10% B
BCXS811035Z
DIODE
REF. NO.
DESCRIPTION
MFR'S PART NO.
D701
Silicon 1SV73-EB
BDAY0220001
COILS
REF. NO.
DESCRIPTION
MFR'S PART NO.
L701
LB-724
BLBY0724001
L702
LB-723
BLBY0723001
TRANSISTORS
REF. NO.
DESCRIPTION
MFR'S PART NO.
Q701
Silicon NPN DB-744 2SC2814-F5
BDBC2814641
Q702
BDBC2814641
Q703
BDBC2814641
RESISTORS
NOTE: All resistors are Carbon Fixed Chip Type, 1/8 watt, � 5% unless otherwise specified.
REF. NO.
DESCRIPTION
MFR'S PART NO.
R701
33k ohm
BRFC183334Z
R702
100 ohm
BRFC181014Z
R703
390 ohm
BRFC183914Z
R704
10k ohm
BRFC181034Z
R705
39k ohm
BRFC183934Z
R706
100 ohm
BRFC181014Z
R707
15k ohm
BRFC181534Z
R708
330 ohm
BRFC183314Z
R709
56k ohm
BRFC185634Z
R710
-Not Used-
R711
Carbon Axial Lead 1k ohm 1/8W �5%
BRFT181024Z
Copyright © 1998,1999,2000 CBTricks.com
