Realisitic TRC-435
Receiver ALIGNMENT PROCEDURE
Alignment Locations
Test Equipment Required
DC Power Supply: 13.8V 2A
Standard Signal Generator: S.S.G.
(27 MHz band, 1 kHz, 30% AM modulation, output impedance 50-ohm)
AC voltmeter
Dummy load (8-ohm, 5W Resistive)
Alignment Procedure
Step
Preset to
Adjustment
Remarks
Vol.: Max.
SQ.: Min.
CH: 18
ANL: Out
L1~L5
Connect the S.S.G. (27.175 MHz) to the antenna jack (J501) and the AC voltmeter across the dummy load (8-ohm) to the external speaker jack (J1). Adjust coils (L1~ L5) for maximum reading on the AC voltmeter.
2
Same as step 1 except
SQ.: Max.
VR2
Set the output level of S.S.G.to 1000uV. Adjust VR2 for 2V AF output.
3
Same as step 1
VR1
Set the output level of S.S.G. to 50uV, no modulation. Adjust VR1 until "9" (fourth digit of LED) lights on.
Copyright © 1998,1999,2000 CBTricks.com
