Realistic
TRC453
RECEIVER SECTION
ITEMS |
MODE |
UNIT |
NOMINAL |
LIMIT |
(ANL. & Noise Blanker Switch Off) |
Max Sensitivity |
AM |
µV |
0.5 |
1 |
SSB |
µV |
0.25 |
0.5 |
Sensitivity for 10 dB S/N |
AM |
µV |
0.5 |
1 |
SSB |
µV |
0.25 |
0.5 |
AGC Figure of Merit 100mV for10 dB Change in Audio Output |
AM |
dB |
90 |
80 |
SSB |
dB |
90 |
80 |
Overload AGC Characteristics |
AM |
dB |
�3 |
�5 |
from 100mV to 1000mV |
SSB |
dB |
�3 |
�5 |
Overall Audio Fidelity at 6 d8 Down |
Upper Frequency |
AM |
Hz |
2100 |
1750 - 2500 |
SSB |
Hz |
3500 |
2500 - 5000 |
Lower Frequency |
AM |
Hz |
450 |
250 - 650 |
SSB |
Hz |
450 |
250 - 650 |
Cross Modulations, RS Standard |
AM |
dB |
60 |
50 |
Adjacent Channel Selectivity (�10 kHz |
AM |
dB |
70 |
60 |
SSB |
dB |
70 |
60 |
Maximum Audio Output Power |
AM |
W |
4 |
3 |
SSB |
W |
4 |
3 |
Audio Output Power at 10% THD |
AM |
W |
3 |
2
SSB |
W |
3 |
2
THD at 500mW Audio Output |
AM: 1 mV Input, 30% |
3
6
80% |
5 |
8
SSB: 1mV Input 1 kHz Single Tone |
3
6
RF Gain Control Range at MaxSensitivity Level |
AM |
dB |
40 |
30 - 60 |
SSB |
dB |
40 |
30 - 60 |
S/N Ratio at Input 1 mV |
AM |
dB |
40 |
34 |
SSB |
dB |
40 |
34 |
Squelch Sensitivity at Threshold |
AM |
µV |
0.5 |
1 |
SSB |
µV |
0.5 |
1 |
Squelch Sensitivity at Tight |
AM |
µV |
1000 |
300 - 3000 |
SSB |
µV |
1000 |
300 - 3000 |
Skirt Rejection (�20 kHz) |
AM |
dB |
80 |
70 |
SSB |
dB |
80 |
70 |
S Meter Sensitivity at "S-9" (No Modulation AM) |
AM |
µV |
100 |
50 - 200 |
SSB |
µV |
100 |
50 - 200 |
Image Rejection Ratio (fo -2 x 10.695 MHz) |
AM |
dB |
76 |
66 |
SSB |
dB |
76 |
66 |
1/2 IF Rejection Ratio (fo -10.695 MHz/2) |
AM |
dB |
90 |
80 |
SSB |
dB |
90
80
Adjacent Sideband Rejection |
SSB |
dB |
60 |
40 |
IF Rejection Ratio 10.695 MHz |
AM |
dB |
85 |
75 |
SSB |
dB |
85 |
75 |
Oscillator Dropout Voltage |
AM |
V |
9 |
11 |
SSB
V
9 |
11 |
Battery Drain at No Signal |
AM |
mA |
250
500 |
SS8 |
mA |
250
500
Battery Drain at Maximum Audio Output Power |
AM |
mA
1000
1500
SS8 |
mA |
1000 |
1500 |
Clarifier Range |
AM |
kHz |
�1.25 |
�0.6 - �2.5 |
SSB |
kHz |
�1.25 |
�0.6 - �2.5 |
Spurious Rejection Ratio |
In Band |
AM |
dB |
65 |
56 |
SSB |
dB |
65 |
56 |
Out of Band |
AM |
dB |
60 |
50 |
SSB |
dB |
60 |
50 |
Desensitivitization (3 dB Desensitivity at 100µV) |
AM |
dB |
60 |
50 |
SSB |
dB |
60 |
50 |
NB & ANL Performance |
AM |
dB |
30 |
20 |
SSB |
dB |
25 |
16 |
NB & ANL Loss |
AM |
dB |
-4 |
-6 |
SSB |
dB |
0 |
-6 |
Dynamic Range |
SSB |
dB |
65 |
60 |
