Realistic
TRC453
TRANSMITTER
SECTION
ITEMS |
MODE
UNIT |
NOMINAL |
LIMIT |
Frequency Tolerance at 77�F (25�C) (5 Minutes after switch on) |
AM |
�0.0005 |
�0.003 |
SSB |
�0.0005 |
�0.003 |
Carrier Power at No Modulation |
AM |
W |
3.8 |
3.5 - 4.4 |
PEP Power, Two Tone, SSB |
SSB |
W PEP |
12 |
10 - 13.2 |
Modulation Distortion at 1 kHz, 80% Modulation |
AM |
3 |
8 |
Spurious Harmonic Suppression |
AM |
dB |
-65 |
-60 |
SSB |
dB |
-65 |
-60 |
Carrier Suppression |
SSB |
dB |
-55 |
-40 |
Unwanted Sideband Suppression (at 2500 Hz 4W PEP 16 dB up) |
SSB |
dB |
-55 |
-40 |
Battery Drain at No Modulation |
AM |
mA |
2200 |
3000 |
SSB |
mA |
500 |
1000 |
Battery Drain |
AM: Max Mod. |
mA |
2200 |
3000 |
SSB: Max Watt PEP, Two Tone |
mA |
2000 |
3000 |
Modulation Frequency Response (1 kHz, 0 dB Reference) |
Lower Frequency |
AM |
Hz |
450 |
250 - 650 |
SSB |
Hz |
450 |
250 - 650 |
Upper Frequency |
AM |
Hz |
2500 |
2000 - 4000 |
SSB |
Hz |
3500 |
2000 - 5000 |
Carrier Power Uniformity, CH to CH at No Modulation |
AM |
W |
0.3 |
0.4 |
Mic Input Level Uniformity, CH to CH for 4 watts Output 2.5 kHz Single Tone -SSB- |
SSB |
dB |
2 |
3 |
Mic Input Level Uniformity, LSB to USB for 4 watts Output, 1.5 kHz Single Tone |
dB |
1 |
3 |
Microphone Sensitivity |
AM: For 50% Mod. |
mV |
0.4 |
1.0 |
SSB: For 4W P.E-P. |
rnV |
0.4 |
1.0 |
AMC Range |
AM: 50 - 10096 Mod. |
dB |
60 |
40 |
SSB: 10 - 13.2 Watts PEP |
dB |
60 |
40 |
Modulation Capability |
95/95 |
80/85 |
Modulation Attack Time |
m Sec |
20 |
25 |
Modulation Release Time |
m Sec |
250 |
100 -500 |
RF Meter (S-9) Indication 2.5 kHz Single Tone |
SSS |
W |
3.8 |
2.5 - 5 |
