Realisitic TRC-476
EXPLODED VIEW PART LIST
Ref. No.
Description
Mfr's Part No.
Main PCB, Blank
411-022-A
2
PCB, LED Display
411-323-A
3
PCB Switch, Blank
411-228-A
4
Wire Plate, 7Pm
429-156-3
5
Wire Plate, 8Pm
429-157-4
6
Connector, ANT, ZNW
421-046-7
7
Socket, 5Pm, TCS-2250-01-101 1
421-529-7
8
Bushing for TR Q304
441-004-5
9
Cord-Power, w/Fuse 250V 1A/250V 2A
504-299
A-1
Stopper, Cord
750-765
A-2
Heatsink, 1C7217, ALP 30x 18x2T, Small
760-704
A-3
Heatsink, 1C7217, ALP 95x22x2T, Large
761-500
A-4
Holder, Ant-Mounting
732-560
A-5
Shield, Housing, SPTE 100x 17x0.3T
771-525
A-6
Plate-Shield, SPTE 36 x 23 x 0.3
771-530
A-7
Plate-Insulation, Fiber, 30 x 30 x 0.3T
905-685
B-1
Escutcheon, ABS 94HB, BLK
801-205-A
B-2
Lens, Lexan
813-680
C-1
Bracket, Set, BLK
723-661
C-2
Bracket, MIC, Cr-Plate
720-095
C-3
Screw, Securing, M6(P = 1) x 9
600-051
C-4
Washer, Rubber, ~7 x ~25 x 1 .5T, BLK
660-138
D-1
Screw, (+) Tapping (B.H) 3.5x6-25, NI
620-084
D-2
Screw, (+) Tapping (T.H) 3.5x6-25, NI
625-007
D-3
Screw, (+) Machine (P.H) M3x 10, ZNY
613-077
D-4
Screw, (+) Machine (B.H) M3x 10, ZNY
613-332
D-5
Screw, (+) Tapping (P.H) T3x6-25, ZNY
623-168
D-6
Screw, (+) Tapping (B.H) T3x6-25, ZNY
623-265
D-7
Screw, (+) Tapping (B.H) 3x 10-2S, ZNB
623-405
D-8
Screw, (+) Machine (F.H) M3x5, ZNY
613-550
D-9
Screw, (+) Tap Tite (P.H) 3x6, ZNY
633-019
D-10
Screw, (+) Machine (B.H) M2.6x6, ZNY
611-138
D-11
Screw, (+) Tap Tite (B.H) 3 x 6, ZNB
633-082
D-12
Washer, Lock "B" Type, M3.5, ZNY
664-000
D-13
Washer, Lock "B" Type, M5, ZNY
664-518
D-14
Washer, Spring M3 ZNY
662-305
D-15
Nut, SS41 M3-1S ZNY
651-024
D212-214
Lamp-LED, GRN, 3V 20mA
252-014-0
D215
Lamp-LED, RED, 3V 20mA
251-138-4
D404
251-137-3
D513
251-079-4
E-1
Cover, Upper, BLK
717-150
E-2
Not Used
E-3
Felt, Strip, 140x6x0.5T
900-204
E-4
Sponge, E.V.A 50x5x2.5T, BLK
893-825
E-5
Not Used
F-1
Cover, Bottom, BLK
717-155
F-2
Not Used
F-3
Felt, Strip, i40x25x0.3T, BLK
905-360
F-4
Sponge, E.V.A., BLK, 50x5x2.5T
893-825
F-5
Felt, Strip, i4Ox6xO.5T
900-204
G-1
Knob, CH-Up, BLK
824-985
G-2
Knob, CH-Down, BLK
824-986
G-3
Coil, Sponge, Channel Up/Down
881-474
G-4
Knob-Control, BLK
824-991
G-5
Knob-Push, PA, BLK
824-995
G-6
Knob-Push, ANL, BLK
824-996
G-7
Knob-Push, NB, BLK
824-997
G-8
Knob-Push, CH9, BLK
824-998
G-9
Body-Front, SPC ZNY
702-195
G-10
Holder, Speaker Mounting
730-015
H-1
Body-Main, SPC ZNY
592-132
H-2
Plate-Name, ALP3
794-438
H-3
Rivet-Blind, ALB
670-025
J1-J2
Jack, Earphone, 3.5Dia, EXT-PA
420-707-6
LED501
Display-LED, GRN, 5V i6OmA
252-014-0
SP-1
Speaker, 8 ohm, 2W
420-102-9
SW1, 5W2
SW-Push, 2P-2C
432-036-3
SW3, 5W4
SW-Touch, EVQ-QSR-~5K
436-020-1
SW7
SW-Rotary, Function
430-043-2
SW9
SW-Push, 2P-4C
432-019-1
SW10
SW-Push, 2P-2C
432-036-3
VR101
VR 50KA w/Nut, Washer � 20%, Volume
450-622-1
VR102
VR 50KB w/Nut, Washer � 20%, RF Gain
450-62i-0
VR201
VR 10KB w/Nut, Washer �20%, Squelch
450-424-9
Copyright © 1998,1999,2000 CBTricks.com
