Uniden PRO500D (UT-317J)
SPECIFICATIONS
GENERAL
1. Channels
40
2. Frequency Range
26.965 MHz 27.405 MHz
3. Semiconductors
10 Transistors, 20 Diodes, 7 ICs� 1-19 Segments
Hybrid Type LED 1 Crystal Oscillators 1
5. Microphone
Electret Condenser Type
6. Speaker
16ohm, 5W
7. Antenna Connector
M-Type
8. Jacks & Connector
Mic 4pin METAL Ext SP 3.5mm
9. Controls
Channel Selector, Volume/Power ON-OFF, Squelch
10. LED Bar Meter :
RF Output Power, Signal Strength
11. Illumination Indicators (LED)
Channel Readout, TX
12. Cabinet Size
W : 116mm H: 36mm D 166.5mm
13. Weight
0.75 kg
14. Accessories
Microphone, Microphone Hanger,
Mounting Bracket with Screws.
MEASUREMENT CONDITIONS
1. Standard DC Power
13.8 V (DC)
2. Test Temperature
250C �50C
3. Standard Audio frequency
1 kHz
4. Standard RF Input
1 mV
5. Standard Ref. Modulation
30 %
6. Standard Ref. Audio Output
0.5 W
7. Standard Ref. Audio Load
8 Q Resistive
8. Antenna Impedance
50ohm
9. Measurement Channel
19
10. Standard Method of Measurement
EIA RS-382 (ISS: 8-26-86)
NOTE : Limit specifications are for measurements on all channels.
RECEIVER
ITEMS
UNIT
NOMINAL
LIMIT
1. Usable Sensitivity (10 dB S/N)
uV
0.7
1.2
2. Max. Sensitivity
uV
0.5
3. Audio Output @ 10% THD
W
4.0
2.0
4. Max. Audio Output Power
W
7.0
3.0
5. Max. S/N @ 1mV
dB
35
25
6. Squelch Sensitivity
Threshold
uV
0.5
1.0
Tight
uV
1000
250 - 4000
7. AGC Figure of Merit(50 mV for 10 dB Change)
dB
85
75
8. Audio Response (Refer to 1
kHz)
@ 6 dB down Lower
Hz
300
400 Max.
Upper
Hz
2000
1600 Min
9. Detector Linearity
1mV, 30%Mod.
%THD
4
7
10. ANL Performance
dB
4
7
11. Adjacent Ch. Rejection
dB
60
45
12. "S" Indicator@ No Mod. (4th LED just ON)
uV
1000
30 Min
13. Spurious Response
22.734 MHZ (CH 40)
dB
50
40
All other freqs.
dB
55
45
11. Image Rejection Ratio (900 kHz)
dB
80
60
15. If Rejection Ratio 1ST & 2ND
dB
70
60
16. 1/2 If Rejection Ratio
dB
55
45
17. Oscillator Drop Out Voltage
V
9.0
11.0
18. Battery Drain
No Signal
mA
230
350
Max. Audio
mA
1400
1700
TRANSMITTER
ITEMS
UNIT
NOMINAL
LIMIT
1. Carrier Power - No Mod.
W
14.0
3.6 - 4.4
2. Frequency Tolerance after 5 min.
�0.002
�0.003
3. Spurious Harmonic Emission
dB
-70
-60
4. Battery Drain
No Mod,
mA
850
1300
80 % Mod,
mA
1300
1700
5. Modulation Freq. Resp. (1 kHz, 0 dB Ref.)
300 Hz
dB
-6
-12
2500 Hz
dB
-6
-12
6. Microphone Sensitivity 50 % Mod.
mV
7
15
7. AMC Range 50�100 % Mod.
dB
36
30
8. Transmit Hum & Noise
dB
50
40
9. Relative Power Meter (No Mod.)
4 just on
3 Min.
10. Transmit Distortion (1 kHz, 80 % Mod.)
4.0
7.0
OVERALL PERFORMANCE
1.
Output Protection : Shall meet for 5 minutes for all VSWR'S (around the Smith Chart) of 20:1 without damage.
2.
Output stability of all VSWR'S (around the Smith Chart) of up to 5:1 under continuous operation of a duty cycle of 5 minutes transmitting, and 1 minute receiving.
3.
Reverse Polarity Protection : Shall have reverse polarity protection and be operable with positive and negative grounding.
4.
Standard Operating Temperature : -30�C +50�C
5.
Storage Temperature : -140�C +70�C
6.
Electrostatic Discharge Protection : All external case and component parts shall withstand the application of 15 kV ESD without causing failure or malfunction to the unit.
Test Conditions - Probe : 150 pF with 500 ohm in series Temp. : 25�C
Note: Nominal specs represent the design specs; all units should be able to approximate these, some will exceed and some may drop slightly below these specs. Limit specs represent the absolute worst condition that still might be considered acceptable; in no case should a unit perform to less than any limit spec.
Copyright © 1998,1999,2000 CBTricks.com
