Uniden PRO500D (UT-317J)
ALIGIMENT OF PLL PORTION
Test Equipment Required
a.
Oscilloscope (0-50MHz)
b.
DC Power Supply (13.8V)
c.
DC Voltmeter (by maximum, 100K ohm/V)
Adjustment Location Layout
Alignment Procedure
STEP
PRESET TO
ADJUSTMENT
REMARKS
TX Mode
Ch 40
No Modulation
L702
Connect DC Voltmeter to TP1 (Lead of R77).
Adjust for approx. 4.5V ±0.1V on DC Voltmeter
2
RX Mode
CH 40
No Modulation
L701
Sane as step 1.
* Note� MIC Signal Line of Dummy MIC requires electrolytic condenser due to MIC Jack J502's No. 1 pin added DC Voltage.
TEST EQUIPMENT CONNECTION
ALIGNMENT OF RECEIVER PORTION
a.
RF Signal Generator (27 MHz Band, 1000 Hz,
30% Modulation & Output Impedance 50 ohm)
b.
AF VTVM
c.
Oscilloscope (0 50MHz)
d.
Dummy Load (8 ohm, 5 watts, resistive (General Output Power))
e.
DC Power Supply (13.8 V)
f. DC Voltmeter
g.
Attenuator 0db=0.5uV
Alignment Procedure
STEP
PRESET TO
ADJUSIMENT
REMARKS
RX Mode
CH19
VOL MAX
SQL MIN
L1, L2,
L3 L11
Connect RF SSG to ANT Connector (J501) and set it 27.185MHz. Connect AF VTVM to EXT. SPK. Jack (J3). Adjust coils for maximum reading on AF VTVM.
2 CH19
No Modulation
VR3
Set the RF Signal Generator to 1000uV output level. Adjust VR3 so that 4th digit of LED meter of the unit just illuminates.
3
CH19
VOL MAX
SQL MAX
VR1
Set the RF Signal Generator to 1000uV output level. Adjust VR1 so that squelch just breaks.
Copyright © 1998,1999,2000 CBTricks.com
