Uniden PRO520E (UT-317A)
SPECIFICATIONS
CB AM TRANSCEIVER MODEL: PRO 520e (UT-317A)
GENERAL
1. Channels:
40
2. Frequency Range:
26. 965 MHz to 27.405 MHz
3. Semiconductors:
12 Transistors, 33 Diodes, 7 IC's
1-19 Segments Hybrid Type LED
4. Crystal Oscillators:
5. Microphone
Electret Condenser Type
6. Speaker:
16 ohm 3 W Max
7. Antenna Connector:
M-Type
8. Jacks & Connectors:
Mic 5pin Din
EXT SP 3.5mm
PA SP 3.5mm
9. Controls:
Channel Selector, Volume /Power ON-OFF,
Squelch, RF Gain, CH9/OFF, PA/GB, ANL/OFF
10. LED Bar Meter:
HF Output Poker, Signal Strength,
11. Illumination Indicators (LED):
Channel Readout, TX
12. Cabinet Size:
W: 116 mm
H: 36 mm
D:166.5 mm
13. Weight: 0.75 kg
14. Accessories:
Microphone, Microphone Hanger, and Mounting Bracket with Screws
MEASURMENT CONDITIONS
1. Standard DC Power:
13.8V DC
2. Test Temperature:
25°C ±5°C
3. Standard Audio Frequency:
1kHz
4. Standard RF Input:
1mV
5. Standard Ref. Modulation:
30%
6. Standard Ref. Audio Output:
0. 5W
7. Standard Ref. Audio Load:
8 ohm Resistive
8. Antenna Impedance:
50ohm
9. Measurement Channel
19
10. Standard Method of Measurement:
EIA RS-382 ( ISS : 8-26-86 )
NOTE:��� Limit specs. Are for measurement on all channels.
RECEIVER (ANL OFF)
ITEMS
UNIT
Nominal
LIMIT
1. Usable Sensitivity (10dB S/N)
uV
0.5
2. Max. Sensitivity
uV
0.5
3. RF Gain Range
dB�
30
20
4. Audio Output @ 10% THD
W
4.0
2.0
5. Max. Audio Output Power
W
7.0
3.0
6. Max. S/N @ 1mV
dB
35
25
7. Squelch Sensitivity:
Threshold
uV
0.5
1.0
Tight
uV
1000
250 to 4000
8. AGC Figure of Merit
(50 mV for 10 dB Change)
dB
85
75
9. Audio Response
(Refer to 1kHz) @ 6 dB down
Lower
Hz
300
400 Max
Upper
Hz
2000
1600 Mim
10. Detector Linearity 1mV,
30% Mod.
%THD
4.0
7.0
11. ANL Performance
dB
4
7
12. Adjacent Ch. Rejection
dB
60
45
13. "S" Indicator
(4th LED just ON) (No Mod.)
uV
1000
500 Mim
14. Spurious Resp.
- 22.734MHz (Ch 40)
dB
50
40
All other freqs.
dB
55
45
15. Image Rejection Ratio (900 kHz)
dB
80
60
16. IF Rejection Ratio 1ST & 2ND
dB
70
60
17. 1/2 i-f Rejection Ratio
dB
55
45
18. OsciLlator Drop Out Voltage
V
9.0
11.0
19. Public Address Output
@ 10%THD
W
3.0
2.0
20. Battery Drain
- No Signal
mA
250
350
- Max. Audio
mA
1400
1700
TRANSMITTER
ITEMS
UNIT
Nominal
LIMIT
1. Carrier Power - No Mod.
W
4.0
3.6 to 4.4
2. Frequency Tolerance after 5 mm.
±0. 002
±0. 003
3. Spurious Harmonic Emission
dB
-70
-60
4. Battery Drain
- No Mod
mA
850
1300
- 80% Mod.
mA
1300
1700
5. Modulation Freq. Resp (1kHz, 0dB Ref)
300Hz
dB
-6
C to -12
2500Hz
dB
-6
C to -12
6. Microphone Sensitivity
50% Mod.
mV
7
15
7. ANC Range 50 to 100% Mod.
dB
36
30
8. Transmit Hum & Noise
dB
50
40
9. Relative Power Meter (No Mod.)
4th just ON
3 Mim
10. Transmit Distortion (1kHz, 80% Mod.)
4.0
7.0
OVERALL PERFORMANCE
1. Output Protection: Shall meet for 5 minutes for all VSWR'S (around the Smith Chart) of 20:1 without damage.
2. Output stability of all VSWR'S (around the Smith Chart) of up to 5:1 under continuous operation of a duty cycle of 5 minutes transmitting, and 1 minute receiving.
3. Reverse Polarity Protection: Shall have reverse polarity protection and be operable with positive and negative grounding.
4. Standard Operating Temperature: -30�C to +50�C
5. Storage Temperature: -40�C to +70�C
6. Electrostatic Discharge Protection: All external case and component parts shall withstand the application of 15kV ESD without causing failure or malfunction to the unit.
Test Conditions - Probe:���
              150 pF with 500 ohm in series
              Temp: 25�C
