Uniden Trucker PTC 104 (UT-332Z)
SPECIFICATIONS
GENERAL
1. Channels.
40
2. Frequency Range.
26.965 MHz 27.405 MHz
3. Semiconductors.
29 Transistors, 53 Diodes, 5 IC's 2 LED's, 2 Digits Channel LED
4. Crystal Oscillators.
1 (10.240 MHz)
5. Microphone.
500 OHM, dynamic Type
6. Internal Speaker.
16 OHM 7 W Max
7. Antenna Connector.
M-Type
8.Jacks&Connector.
Mic4p METAL Ext SP 3.5mm PA SP 3.5mm DC Power 3pType
9. Controls.
Channel Selector, Volume/Power ON/OFF, Squelch, RF Gain, Mic Gain, Ch9/OFF PA/CB, ANL/NB/OFF CAL/SWR/MOD
10. Meter (Analog Type).
RF Output Power, Signal Strength TX Modulation, S.W.R
11. Illumination Indicators (LED):
Channel Readout, TX, RX
12. Illumination (Pilot Lamp):
Meter Back Light
13.CabinetSize.
W: 185.5 mm H: 58.5 mm D: 230.5 mm
14. Weight.
1.5kg
15. Accessories.
Microphone, Microphone Hanger, DC Power Cable with Built in fuse, Mounting Bracket with Screws
MEASUREMENT CONDITIONS
1. Standard DC Power.
13.8VDC
2. Test Temperature.
250C �50C
3. Standard Audio Frequency.
1 kHz
4. Standard RF Input.
lmV
5. Standard Ref. Modulation.
30 %
6. Standard Ref. Audio Output.
0.5 W
7. Standard Ref. Audio Load.
8 OHM Resistive
8. Antenna Impedance.
50 OHM
9. Measurement Channel.
19
Note: Limit specifications are for measurement on all channels.
RECEIVER (ANI OFF)
ITEM
UNIT
NOMINAL
�LIMIT
1. Usable Sensitivity CB (10 dB S/N)
uV
0.5
2. Max. Sensitivity
uV
0.5
3. RF Gain Range
dB
40
35
4.AudioOutput @10%THD
W
4
3
5. Max. Audio Output Power
W
7
6
6. Max.S/N@lmV
dB
45
35
7. Squelch Sensitivity
Threshold
uV
0.5
1.0
Tight
uV�
1000
250 to 4000
Hysteresis @Tight
dB �
4
2 to 7
8.AGC Figure of Merit
(50 mV for 10 dB Change)
dB
90
75
9. Audio Response (Refer to 1 kHz) @6dB down
Lower
Hz
350
500 Max
Upper
Hz
3300
2000 Mm
10. Detector Linearity
1 mV, 30 % Mod.
%THD
2.0
3.5
11. Delta Tune Voice Lock Range
kHz
N/A
N/A
12. ANL/NB Performance
ANL
dB
4
7
ANLINB
dB
2.0
3.5
13. Blocking
dB
75
70 (Ref. To 100uV)
14. Cross Modulation @1 mV
dB
45
35
15. Desensitization
dB
60
50 (Ref.To 100 uV)
16. Adjacent Channel Rejection
dB
60
50
17. "S-9" Sensitivity @No Mod.
uV
100
50 to 250
18. Spurious Response
- 22.725MHz (Ch 40)
dB
50
45
- All other frequencies
dB
60
50
19.Image Rejection Ratio(910kHz)
dB
80
70
20. IF Rejection Ratio 1st & 2nd
dB
70
60
21. Oscillator Drop Out Voltage
V
9.0
11.0
22. Public Address Output @10%THD
W
5
3
23. Battery Drain
- No. Signal
mA
320
450
- Max. Audio
mA
1200
1600
TRANSMITTER
ITEM
UNIT
NOMINAL
LIMIT
1. Carrier Power - No Modulation
W
4.0
3.6 to 4.4
2. Frequency Tolerance after 5min
�0.002
�0.003
3. Spurious Harmonic Emission
dB
-70
-60
4. Battery Drain
-No Modulation
mA
1000
1300
-80% Modulation
mA
1250
1500
5. Modulation Freq. Resp (1 kHz, 0 dB Reference)
300Hz
dB
-6
0 to -12
2500Hz
dB
-6
Oto-12
6. Microphone Sensitivity 50%Mod.
mV
0.5
1.0
7AMC Range 50 to 100% Mod.
dB
45
35
8. Transmit Hum & Noise
dB
50
40
9.SWR
@1:1
ltol.8
@2:1
1.Sto3.5
10. Transmit Distortion (1 kHz, 80 % Modulation)
3.0
8.0
OVERALL PERFORMANCE
1. Output Protection : Shall meet for 5 minutes for all VSWR,S (Around the Smith Chart) of 20:1 without damage.
2. Output stability of all VSWR'S (around the Smith Chart) of up to 5:1 under continuous operation of a duty cycle of 5 minutes ransmitting, and 1 minutes receiving.
3. Reverse Polarity Protection: Shall have reverse polarity protection and be operable with positive and negative grounding.
4. Standard Operating Temperature: -300C + 500C
5.��� Storage temperature: -400C � + 700C
6.��� Electrostatic Discharge Protection: All external case and component parts shall withstand the application of 20 kV ESD without causing failure or malfunction to the unit.
Test Conditions - Probe: 150 pF with 500 Q in series
Temp. & Humidity: 250C @ 20% or less RH
Note: All working samples submitted as well as any changes to the product following production approval must be tested for ESD protection.
Copyright © 1998,1999,2000 CBTricks.com
Please join the CB Tricks E-Mail group or e-mail us at webmaster@cbtricks.com and send a message if you discover a problem.
