Uniden
Trucker PTC104 (UT-332Z)
Integrated Circuits
SYMBOL |
DESCRIPTION |
PARTS CODE |
IC001 |
INTEGRATED CIRCUIT TA7310P-U |
BDEYO1O9002 |
IC002 |
BDEYO1O9002 |
IC003 |
INTEGRATED CIRCUIT D2816C |
BDEY0884001 |
IC501 |
INTEGRATED CIRCUIT UPC1242H |
BDEYO47100l |
IC502 |
INTEGRATED CIRCUIT L7808CV |
BDEYO924001 |
Transistors
SYMBOL |
DESCRIPTION |
PARTS CODE |
Q001 |
TRANSISTOR: DB-259 2SC1675-L |
BDBC1675111 |
Q002 |
BDBC1675111 |
Q003 |
TRANSISTOR: DB-224 2SC945A-Q |
BDBC0945507 |
Q004 |
TRANSISTOR: DB-027 2SA733A-PB |
BDBA0733541 |
Q005 |
BDBC0945507 |
Q006 |
BDBCl67S111 |
Q007 |
TRANSISTOR: DB-301 2SC941TM-O |
BDBC0941523 |
Q008 |
BDBC0945507 |
Q009 |
BDBC0945507 |
Q011 |
BDBC0945507 |
Q012 |
BDBC1675111 |
Q013 |
BDBC1675111 |
Q014 |
TRANSISTOR: DB-295 2SC1674-L |
BDBC1674111 |
Q015 |
TRANSISTOR FET: DC-019 2SK192A-BL |
BDCB0192533 |
Q016 |
BDBC1675111 |
Q017 |
BDBC0945507 |
Q018 |
BDBC0945507 |
Q019 |
BDBC0945507 |
Q021 |
BDBC0941523 |
Q022 |
BDBC0945507 |
Q023 |
BDBC0945507 |
Q024 |
BDBC0945507 |
Q025 |
TRANSISTOR: DB-027 2SA733A-FB |
BDBA0733541 |
Q026 |
BDBA0733541 |
Q027 |
TRANSISTOR: DB�224 2SC945A-Q |
BDBC0945507 |
Q031 |
BDBC1675111 |
Q033 |
BDBC1675111 |
Q501 |
TRANSISTOR: DB-310 2SC2075 |
BDBC2O75000 |
Q502 |
TRANSISTOR: DB-318 2SC1957-Q |
BDBC1957116 |
Diodes
SYMBOL |
DESCRIPTION |
PARTS CODE |
D001 |
DIODE: 1N60 AM TAPING |
BDAY0001013 |
D002 |
DIODE: AX TS 26 1N4148 TAPING |
BDAY0246003 |
D003 |
BDAY0001013 |
D004 |
DIODE: AX TS 26+ 1S1555 TAPING |
BDAY0181002 |
D005 |
BDAY0181002 |
D006 |
BDAY0181002 |
D007 |
BDAY0181002 |
D008 |
BDAY0181002 |
D009 |
BDAY0181002 |
D011 |
BDAY0181002 |
D012 |
BDAY0181002 |
D014 |
DIODE: 1N60 P TAPING |
BDAY0001014 |
D015 |
BDAY0001014 |
D017 |
DIODE: AX TS 26+ S5566G TAPING |
BDAY0529001 |
D018 |
BDAY0181002 |
D019 |
BDAY0181002 |
D021 |
BDAY0181002 |
D022 |
BDAY0181002 |
D023 |
BDAY0181002 |
D024 |
BDAY0181002 |
D025 |
DIODE: 1SV73-EB |
BDAY0220001 |
D026 |
DIODE: AX TS 26+1S1555 TAPING |
BDAY0181002 |
D027 |
BDAY0181002 |
D028 |
BDAY0181002 |
D029 |
BDAY0181002 |
D031 |
BDAY0181002 |
D032 |
BDAY0181002 |
D033 |
BDAY0181002 |
D034 |
BDAY0181002 |
D035 |
BDAY0181002 |
D036 |
BDAY0181002 |
D037 |
BDAY0181002 |
D038 |
BDAY0181002 |
D039 |
BDAY0181002 |
D042 |
DIODE: ZENER AS TS 26 + HZ5C1 TAPING |
B0AY0492002 |
D043 |
BDAY0181002 |
D044 |
BDAY0181002 |
D045 |
BDAY0529001 |
D046 |
BDAY0181002 |
D047 |
BDAY0181002 |
D351 |
BDAY0181002 |
D352 |
BDAY0181002 |
D353 |
BDAY0181002 |
D354 |
BDAY0181002 |
D355 |
BDAY0181002 |
D356 |
BDAY0181002 |
D357 |
BDAY0181002 |
D358 |
BDAY0181002 |
D359 |
BDAY0181002 |
D361 |
BDAY0181002 |
D362 |
BDAY0181002 |
D363 |
BDAY0181002 |
D551 |
DIODE: LED LL-2255SL |
BDAY0530001 |
D552 |
DIODE: LED TLR-124 |
BDAY0100001 |
D553 |
DIODE: LED TLG-124A |
BDAY0116001 |
D555 |
BDAY0181002 |
Please join the CB Tricks E-Mail group or e-mail us at webmaster@cbtricks.com and send a message if you discover a problem.
