Uniden Trucker PTC104 (UT-332Z)
ALIGNMENT PROCEDURES
ALIGNMENT OF PLL
Test Equipment Required
Power Supply: 13.8VDC
TP6: Probe Ground
Oscilloscope
DC Voltmeter
Preparation for Alignment
PA/CB
: CB
CH9/OFF
: OFF
Alignment Procedure
Step
Preset to
Adjustment
Remarks
RX 19CH
L22
Connect the oscilloscope to TP1. Adjust L 22 for maximum reading on the oscilloscope.
2
TX 40CH
L17
Connect the Dc voltmeter to TP2. Adjust L 17 for 3.2 � 0.1V reading on the DC voltmeter.
3
RX 1CH
Check if the voltage is 0.8V at TP2.
Before step 1 start, should be locked C99,C104, C10Sand C106.
After the alignment, lock L17 using wax.
Test Equipment Connection
ALIGNMENT OF RECEIVER
Oscilloscope
S.S.G.: 1 kHz, 30%, 19 CH
AC Voltmeter
AF Scope
NB/ANL/OFF: OFF
RE Gain: Max. (CW)
PA/CB: CB
Squelch: Min.(CCW)
CH9/OFF: OFF
Volume: Max. (CW)
Alignment Procedure
Step
Preset to
Adjustment
Remarks
RX 19CH
L2-7,16 and 23
Connect the AC voltmeter to speaker. Adjust coils for maximum reading on the AC voltmeter. (Keep S.S.G. level to meet AF standard output power or slightly less power.)
2
RX 19CH Squelch Max.(CW) SSG:66dB
VR 1
Adjust VR 1 so that just appear AF level.
3
RX 19CH SSG:46dB Non Mod.
VR2
Adjust VR2 so that just indicated to "SIG9�
4.
RX 18CH NB/ANL SW: NB/ANL
L1
Connect the oscilloscope to TP5. Adjust L1 for maximum reading on the oscilloscope.
Copyright © 1998,1999,2000 CBTricks.com
Please join the CB Tricks E-Mail group or e-mail us at webmaster@cbtricks.com and send a message if you discover a problem.
