Hi all what cleaner's do you use - and what is the best way to use them? Also can they be used on tube type Raidos and Amps? Thanks God Bless.
You mean to tell me i can clean the inside of a cb Raido with soap and water? Things such as simple green and such. Will this hurt the tunners and caps meaters that are inside the Raido. Just want to make sure befor i tear something up. On tube type Amps and Raidos do you pull the tubs or leave them in? will this cause rust to form inside the raido? Thanks God Bless![]()
Hey folks what is the best way to discharge a tube amp so i dont get the crap bit out of me. I recall my Dad useing a scewdriver that was about a foot long and real thin to short out the caps and across the tubes to the case. I want to clean them up on the inside and clean the tunner's and such. Any help with this i would be greatfull. And if you know tell me the best way to do this tubes and caps Thanks .
