i was really going on faith and working in the dark on that one. and a good part of the thread is my ideas not doing what i wanted
. but i eventually got what i wanted
i highly suggest reading these three threads if you're at all interested in these type antennas .
http://www.worldwidedx.com/cb-antennas/144592-vector-4000-remake.html
homers bottom x bracket looks to be about as strong as my plate bracket and allows the bottom of the basket elements to be off the bottom of the vertical the inch or so that they need . i think folks would be worried about their roof flying off before either of our bottom attachments fail in wind and homers is simpler to make and can be made with aluminum strips from lowes/home depot . and be sure to use his idea for pex for the gamma insulator. also be sure to double wall at least the two lower section of the vertical or use the 1/4 inch wall tubing . when i put mine back up i'm gon tripple wall the lower section and double the second and third sections . then the 2 inch O.D. bottom will fit perfectly in the 2 inch inside diameter conduit i use for mast
also , take your time reading these two threads .....
http://www.worldwidedx.com/cb-antennas/31799-avanti-sigma4-alternative-view-point.html
http://www.worldwidedx.com/cb-antennas/36412-modified-vector-4000-a.html
i've read through each several times and find new things that make more sense than it did before every time .
good luck with your build and be sure to do a thread with pics as you go so if i see you do something i like better than i do .... i can steal .... ummmmm , i mean copy your idea
my results didn't jive with what i was told at Eham ..... there was even a guy that said he used to work at avanti and wasn't a fan of my antennaLOL . but it gave me better results than any of my previous antennas so i'm sticking with it . my TX?RX results trump any comments made by anyone on any forum . and i'm fully open to these type antennas not being the best for everyone .... but i believe it could be the best antenna for most folks ... if it will hold up to their weather extremes .
BTW .... you should make a thread here about your tower explaining how you built it and some pics to show what you did![]()
Hey Booty in your situation, I agree that your home brew Vector could provide the results you noted above in red. The way I read the Eham thread, I think WB6BYU, Dale, agrees as well. But Dale was trying to make a point, just like I do when I claim the advantage for the taller vertical antenna is primarily due to the additional height the design provides...in a similar installation as you use.
The only thing I might disagree about regarding the Sigma/Vector is how it works to provide such a difference, and for me that is amazing, in its own right and without applying some magical or mysterious function going on in the base of the antenna...that has a non-apparent collinear effect.
I think WB6BYU was alluding to this, without going into details, when he briefly described the issues with a 5/8 wave.
http://www.eham.net/ehamforum/smf/index.php/topic,75921.0.html
He just didn't go on to talk about the Avanti idea to make the typical 3/4 wave radiator work without showing a worthless radiation angle issue, and considering his thoughts for how the 5/8 wave was affected by the bottom of the antenna being out of phase.
I know your Vector results don't agree with what was said over there, but did the experience bring anything good to light for you?
Or, do you think you just happend to run across the same guy that Bob described as having also talked to Master Chief in the past, and was just a guy disagreeing...because he worked for Avanti, didn't like the Sigma 4 design, and was currently just working to make through glass mobile antennas?
