Finally decided to give the 102" a try, I used a wilson 5000 5" mast and a couple connectors. For a adjustable 108" It seems to work quite well, SWR is 1.2 on 1 and just moves the needle on the Vanco enough to say it moved but not enough for a reading on 40. Made a few local contacts but have not had the chance to see if there is an improvement over the P10k. I stole the idea from a local radio head friend and thought it was worth sharing. I will be moving it the the inside right rear bed rail but it will do for now where it is.
