If you all weren't so cynical, you may learn something about ferrites and their useful applications.
......WRAP A FERRITE!he is obviously an appliance operator that needs to
I have three ground rods at the base of my tower but they are for lightning. I hope I never need them and they were a waste of money.
I have a flea infestation.......time for some toroids![]()
Hey don't get your knickers in a knot, I was simply pointing out that ferrites have their uses. You all jumped on this guy and ridiculed him, I doubt you would do that to his face. Maybe I will ridicule you about your rf grounding practices, how would you like that? I get the feeling that you don't really understand or know why you're placing these grounds, you're just regurgitating something you heard or read from some old ham. A lot of people with radio will put someone down and then drop some technical reference without elaborating on the details to make themselves look good. It's called an inferiority complex.
How can lightening protection/ grounding be a waste of money? I have used the tech correct copper before, but they are expensive. There is some that are galv clad and cheaper. Recently I just used several 1/2" to 3/4" dia. pipe about 5 foot long. You can use a variety of things to attach the wire with. I drilled and tapped 3/8" hole and attached with wire lug connector. I'm at sea level so buying the expensive stuff ain't worth it. Most of my grounding supplies were scrap. I have used rebar when traveling with my camper when I find the power pedestal is not grounded. Camper was shocking me with 22 volts. sure saved my power converter.
