free 1-16 pill amp plans
  • Start date Start date
The only bad thing I see here (now) is that there seems to be some adjustments or something that needs to be done considering HG's are being used. Maybe it's just me? I started off using these plans myself and they worked very well for me.. I guess they're a good jumping off point?
Yes adjustments must be made for whatever pill being used besides toshiba 2879's. But yes its a good starting point
Write your reply...
  • @ Geoexplorer69:
  • @ Geoexplorer69:
