Ok Eddie, in the interest of not being too confusing I am starting over with this post and all new measurements.
These are the proper dimensions.
Please disregard the old measurements.
I had some issues with the first ones.
The dia of the coil material is 1/4 inch.
The coil length is 5 15/32 center to center of the material where it makes the bend, I have to eyeball this so that's as close as I can get.
The coil turns are 7/8 of a inch apart center to center of the material.
The coil ends are 180 degrees apart.
The coil comes out of the insulator, makes the bend and then there is 5 full turns, and then a half a turn to get back in the other side.
The insulator is 5 7/8 long.
The length of the material of the coil to were it goes into the insulator is 7/16.
This is to the center of the bend where it goes into the insulator.
The outside dia of the coil is 3 7/64 across.
The top section is 6 1/4" inch long and dia is 7/8" same as the bottom tube.
The full length of the 22" shaft shaft antenna is 81 inches.
The full length of the 27" shaft antenna is 85 1/2"
And on both the 27" and 22 " the bottom shaft is 7/8" dia.
46 1/2" is the whip length for the 27" shaft and whip length for the 22" shaft is 46 3/4" to the top of the corona ball.
These are exposed lengths.
The whip is 0.125 in the.
I brought them back with me so if you need other measurements let me know.
