Yup, that can do it...
Firstly thank you for this picture.
Secondly, yes, but in SSB mode. It looks at "peak" and R171 "swamps" or changes the sensitivity of the Diode - notes the 0.22V in TX - but notice the MINUS " - " symbol.. It's looking for spikes and the diode conducts really heavily when the RF wave ever gets to a point where the negative peaks of the RF signal go below the Detectors (R171 and D46) reverse biased condition and then the Gate conducts because the Diode's orientation in the circuit is now forward biased.
L25, C154 CT7 - form a tunable trap to sense RF, L25 takes the DC the Diode makes in the detection - and keeps the signal level low enough to keep the FET that 2SK68 (really old unit) from blowing up (perforation)...
Did not know if you were aware of this, but a circuit like this can also function even when it's not supposed to. The Diode used in this fashion will make a small current appear and have power to affect the Limiter amp located in another section of your Sams manual.
- See Block 2 it shows 9.50V ?
- With the discrete parts (not the Diode, remove it for a moment mentally) The FET conducts to ground when the signal approaches a threshold - with out the Diode - as a level of peaks in the RF output envelope.
- Now, put that Diode back in, it helps to rectify these peaks, and when these peaks Go Negative, that Diode helps to make this circuit more sensitive to these negative peaks.
When the power is off, this circuit is not, it's still working - sensing the levels of RF power and since the diode can trigger the Gate into functioning - that DC power from Block 2 doesn't need to even be on, it can send a signal to ground one of two ways, The line being more positive than ground - or the FET itself is DAMAGED and the Gate is perforated (shorted) into the substrate, it's not insulated from it anymore - so the signal the Diode makes, can now go back into the line that's labeled MOD SSB and affect the limiter amp.
So if you're having trouble, we can suggest some ideas but what radio is this in? (520D?)
